PostPosted: Mon Feb 02, 2015 8:48 am
Anyone use this block on the 2.2 ecotec and does the pipe from the water pump to the waterneck connect to it.
PostPosted: Mon Feb 02, 2015 11:15 am
Yes the block works, as far as the cross over, thats a toss up. Mine didn't. Had to go get one from an 06 cobalt.
PostPosted: Mon Feb 02, 2015 9:52 pm
The block will bolt up, however, like blackoutt said, you may need the longer 2.4 cross over pipe. It really depends on which year 2.2 you have.
-AFI
PostPosted: Mon Feb 02, 2015 11:53 pm
I have a 05 2.2 from a sunfire
PostPosted: Tue Feb 03, 2015 2:52 pm
Easiest way to figure it out is, pull the crossover off and lay it on a table and see if both ends lay flat. The old crossover I had one end entered the old block on an angle. Both ends on the 2.4 crossover are the same. Sorry it's tricky to explain, needless to say the 2.4 has a little longer crossover and both sides enter the pump and block at the same angle.
