It is currently Sat May 02, 2026 5:57 pm
 Post subject: Ecotec fuel pump
PostPosted: Mon Sep 30, 2013 6:42 pm
Im running the chep summit efi pump. I had to pull it out and found this rubber sticking out the end it runs fine but it was not there before im going to swap it out. Anyone have any ideas what it is or why with would happen?
 Post subject: Re: Ecotec fuel pump
PostPosted: Mon Sep 30, 2013 6:46 pm
Also anyone running a pump other then this one or the e2000 pump been looking on summit most are only rated for 45psi or less and the better name ones that are over 50psi are over $200
PostPosted: Mon Sep 30, 2013 6:53 pm
i run a e2000 of ebay about 40 bucks looks just like the sumit pump
PostPosted: Mon Sep 30, 2013 7:58 pm
has to be something from inside the pump because if in went through the pump you would of heard it.
PostPosted: Mon Sep 30, 2013 9:35 pm
How about one of these http://www.megamanual.com/v22manual/minj.htm#supply
PostPosted: Tue Oct 01, 2013 11:50 am
Huey wrote:
Thanks thats what I was looking for
PostPosted: Tue Oct 01, 2013 4:37 pm
This is what I am running. This is also what some of the desert racers are running.
http://www.ebay.com/itm/Mercedes-MEYLE- ... 9d&vxp=mtr
PostPosted: Tue Oct 01, 2013 4:38 pm
I should have added I have my pressure regulator set at 60 psi
PostPosted: Thu Oct 03, 2013 9:09 pm
Here is what im running now. I picked up off ebay as NOS for 38 shipped. If anyone is looking for a quiet pump this is the one to get. It makes NO sound at all.
PostPosted: Sat Oct 05, 2013 8:00 am
Here's what we run in all of ours and have had good luck so far
http://www.speedwaymotors.com/MSD-2225- ... 31226.html
PostPosted: Sat Aug 02, 2014 7:22 am
Is the MSD pump loud?
PostPosted: Sat Aug 02, 2014 4:06 pm
I think its the same as the summit pump. But I have heard of 2 jeep guys burning up the msd one less then a year.
PostPosted: Sat Aug 09, 2014 6:20 pm
Thanks for the quick reply. I couldn't find the quiet ACDelco EP424 you recommended. Must have stopped making it?
PostPosted: Sat Aug 09, 2014 8:34 pm
http://pages.ebay.com/motors/link/?nav= ... 12&alt=web
PostPosted: Sun Aug 10, 2014 7:06 pm
Thanks man - I ordered it. Ive been looking for a quiet pump! :D
PostPosted: Sun Aug 10, 2014 8:36 pm
No problem. I think you will be very happy with it. 8-)
PostPosted: Wed Nov 05, 2014 4:23 pm
Rock auto.. 89 f-150 pump about $50, we've been running 3 of them for over 2 years. No problems.
ya cant beat fun!
