PostPosted: Sun Jan 19, 2014 2:42 pm
I have a 3.5L VTech and it will not start when it warms up. It will jump start with no problem and the alternator is charging fine. I figured the battery must be the issue and I replaced the battery.
Still having the same problem with the new battery. If the buggy has been sitting for days, it will fire up with no problem. However, once the engine warms up, the engine will not turn over.
I am currently running a VW 094 starter for an Automatic bus on Honda V6. I think I need a hi-torque starter but I wanted to make sure that sounds correct before I drop $200 on a new starter.
PostPosted: Sun Jan 19, 2014 3:53 pm
http://www.woodsbuggy.com/viewtopic.php?t=11144Starters
I have never had a problem with my starter. If you buy the starter on ebay no core and half the $.
PostPosted: Sun Jan 19, 2014 5:03 pm
I had that problem and it turned out the cables were corroded inside. Id check them and make sure you have good grounds. I ran the auto stick on my suby and never had a problem after new cables
PostPosted: Sun Jan 19, 2014 5:33 pm
Thanks Stevo.. I will check the cables and hopefully that will fix the problem.
PostPosted: Sun Jan 19, 2014 7:03 pm
The solonoid contacts are a prime suspect for that too, they overheat when hot and the resistance goes up so far there's not enough current passing to crank the engine.
PostPosted: Sun Jan 19, 2014 8:07 pm
The above link doesn't work "bluebuggy" and I need a starter. Does anyone have a new link to this ?
PostPosted: Sun Jan 19, 2014 9:23 pm
It was ?? But I cant see it now to
This is what I run
http://www.thesamba.com/vw/classifieds/ ... ?id=694797
I payed 50 looks like its went up but I would still buy and got starter off ebay new for 65 I think
