 Post subject: 2.4 l ecotech ???
PostPosted: Sun Aug 18, 2013 10:20 am
i see a lot of info on the 2.0 & 2.2 but what about the 2.4 ? what about vvt engines?
 Post subject: Re: 2.4 l ecotech ???
PostPosted: Mon Aug 19, 2013 8:04 pm
One of my friends run a 06 2.4 and it runs really good.
PostPosted: Tue Aug 20, 2013 8:35 pm
is it a drive by wire ? what computer is he running ?
PostPosted: Tue Aug 20, 2013 9:28 pm
All 2.4 are drive by wire with the stock ecu. I believe you can run a tb from a 2.2 and custom ecu but its going to run you 1k+.
PostPosted: Tue Aug 20, 2013 10:33 pm
His is drive by wire.
PostPosted: Fri Aug 23, 2013 8:53 pm
thanks for the info but i just bought a 2.2
PostPosted: Fri Aug 23, 2013 8:54 pm
thanks for the info but i just bought a 2.2 and plan to run it on my buggy with an 091 trans
PostPosted: Fri Aug 23, 2013 11:00 pm
don't unless you run some baby chains. When you have to defy gravity you will have to let off the gas to keep from flipping over backwards.
PostPosted: Fri Aug 23, 2013 11:06 pm
2800 passat can't wait to see your baby chains in action at biscuit. I'm coming with spectators. Lol
PostPosted: Thu Sep 19, 2013 10:48 pm
For the amount you spend on a 2.2, there really isn't a reason to bypass the 2.4L VVT motor. It really is superior in ever way. We chose the 2.4L in our off-road applications. The LE5 is a larger 2.4 L—2,384 cc (145.5 cu in)—version of the Ecotec. Both the 88 mm (3.5 in) bore and 98 mm (3.9 in) stroke are larger, and Variable Valve Timing [VVT] on the intake and exhaust improve low-end torque. Compression is 10.4:1. Other reasons include:
* The cost difference between the 2.2L L61 is negligible.
* The 2.4L LE5 offers more displacement
* The 2.4L LE5 supports VVT
* The 2.4L LE5 supports Electronic Throttle Body
* The 2.4L LE5 uses the 'reinforced' GM GEN II block [the same block as the LSJ/LNF]
* The early production [2006-2007] 2.4L LE5's are BOOST READY w/ forged pistons, rods, & crankshafts
* The 2.4L LE5 has targeted oil jets to cool pistons
* The 2.4L LE5 has a higher flowing intake manifold [than the L61]
* The 2.4L LE5 uses 58X crankshaft position sensing
* The 2.4L LE5 uses digital crankshaft & camshaft position sensors
* The 2.4L LE5 uses an individual coil on plug ignition system
* The 2.4L LE5 uses the vastly superior 32-bit E67 ECM
Just something to think about! The 2.2 L61 is a good motor, don't get me wrong! If you need harness or ECM tuning support let me know.
Shaun
PostPosted: Fri Sep 20, 2013 10:14 am
Other than the no replacement for displacement thing most of this list holds true for 07 and up L61.
PostPosted: Fri Sep 20, 2013 11:14 am
I agree with you on most of similarities I've listed, however, the L61 was re-dubbed LAP for late 2008. When I see folks going 2.2 they are usually the early version L61. Just some food for thought.
Shaun
PostPosted: Fri Sep 20, 2013 12:01 pm
The only thing I miss is the Cavalier power steering pump driven off the camshaft because it would sure make it easier to put the power steering on.
