PostPosted: Thu Sep 15, 2011 9:44 pm
What are you guys running?
I just traded for giveitagallon's buggy and the summitt fuel pump is on borrowed time. It runs for about 30 minutes or so then the pump warms up and shuts off.
I want to stop and Napa on my way home from work tomorrow, buy a fuel pump that will work correctly, and install it. It's ran inline, plenty of room to mount it, shouldn't be anything crazy needed. I've ran a Ford Crown Victoria pump inline before, I was unsure about the pressure needed and wanted to make sure before I did something wrong.
Thanks.
PostPosted: Thu Sep 15, 2011 11:11 pm
use a 1987 vw vanagon fuel pump this is the pump that we use
PostPosted: Fri Sep 16, 2011 11:35 am
I think any EFI pump should work. Your Subaru should have a fuel pressure regulator at the end of the fuel rail right before the return. The pressure should be around 45psi I believe. I run a walbro 225 or something... its been a while :roll: its a very common pump.
PostPosted: Fri Sep 16, 2011 8:35 pm
I have a toyota 1984 with 45 psi if that will help.From Pull a Part. Threw it in my pocket and walked out.$200 carYou'r paying the investers on Wall Street big dividends . Walk out.
PostPosted: Fri Sep 16, 2011 9:40 pm
If u go to napa they carry the pump i run. It is a inline ford pump part # is E2000.. It works great for me......
"I got this..."
PostPosted: Fri Sep 16, 2011 10:00 pm
Receiving stolen property is one thing, receiving stolen property that has crossed state lines makes you a felon.
PostPosted: Mon Sep 19, 2011 8:19 am
That's the one I went with. It ended up not being the fuel pump anyways though. A connector on the wire had mud in it and was arcing in and out.
That pump is loud, I can't even hear the motor running at idle. :lol:
PostPosted: Wed Dec 07, 2011 8:02 pm
i used a fuel pump out of a jaguar v12 they seem to hold up thats what suby steve hadin his buggy that what we ran in are subarus to
*subiepower*
PostPosted: Thu Dec 08, 2011 10:15 am
Outfront Motorsports gave me one with my motor and it works like a champ. They said they use to use bosch but these outlast them 2 to 1.
PostPosted: Thu Dec 08, 2011 10:34 am
The Walbro is the most common replacement pump with the Subaru guys. I would go with it.
