| Starters http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=11144 |
| Author: | bluebuggy [ Sun Jan 30, 2011 12:46 pm ] |
| Post subject: | Starters |
Im going to be running a ecotec with a 6rib and need a starter. So what starter are you guys running on your ecotec's?? I have been thinking about milling the bell down to run a Firebug style starter Will a stock 091 starter start it?? Thanks |
| Author: | mudnut [ Sun Jan 30, 2011 1:27 pm ] |
| Post subject: | Re: Starters |
stock 091 will work fine. buddy has one on his for over a year now |
| Author: | Maddog [ Mon Jan 31, 2011 6:41 pm ] |
Firebug has 1 for sale, the type he uses is the best I know of including those aftermarket hi-torque starters. |
| Author: | tw9294 [ Tue Feb 01, 2011 9:38 pm ] |
mudnut wrote: stock 091 will work fine. buddy has one on his for over a year now i tried a brand new stock 091 starter and it turns too slow. It did start it but barely. I put one of the high tourqe starters on and it wizzes right over. |
| Author: | bluebuggy [ Tue Feb 01, 2011 9:50 pm ] |
Thanks im planning on getting the high tourqe starter |
| Author: | davehix [ Tue Feb 01, 2011 10:58 pm ] |
I didnt forget http://www.thesamba.com/vw/classifieds/ ... ?id=694797 |
| Author: | bluebuggy [ Wed Feb 02, 2011 11:36 pm ] |
THANKS dave Im ordering one looks like it would work really good!! |
| Author: | bluebuggy [ Fri Feb 11, 2011 7:50 pm ] |
Has anyone tried this http://www.thesamba.com/vw/classifieds/ ... ?id=694797 I ordered one and the starter but the starter firebug uses is a 9 tooth this one calls for a 10 tooth just wanted to see if anyone has one |
| Author: | Firebug [ Fri Feb 11, 2011 10:07 pm ] |
That adapter is a great idea,,then you still have your warantee on the starter. The ones I convert are altered and the waranty may not be good. I imagine the number of teeth is important and it should turn CCW . I am interested in hearing about the 10 tooth starter. |
| Author: | bluebuggy [ Fri Feb 11, 2011 10:12 pm ] |
It does go ccw. i should have it monday so i will post some pics |
| Author: | Firebug [ Fri Feb 11, 2011 10:16 pm ] |
bluebuggy wrote: It does go ccw. i should have it monday so i will post some pics $60 bucks aint bad,,those starters are wicked strong,,,maybe our resident machinist can duplicate them ,,,hear me MadMike????? |
| Author: | buggiejunky [ Fri Feb 11, 2011 10:34 pm ] |
me and another guy aready run them i have a factory tdi starter on my 2387 11.5 to 1 compression works awesome in my opinion they have twice the speed and torque of a imi high torque starter the other guy has one of the starters from ebay ( i have one too a spare ) he has no complains about it either i think i have some adapters already made ill check tommorrow if u guys want one pm me and well see what we can work out |
| Author: | bluebuggy [ Sat Feb 12, 2011 5:39 pm ] |
got my starter today here is a side by side with the one from my 3 rib the drive gear is bigger being 10 tooth but the teeth are the same on both ![]() ![]()
