It is currently Mon May 04, 2026 5:22 pm
 Post subject: high idle
PostPosted: Tue Jan 25, 2011 10:07 pm
my subaru 2.2 has been running at high idle around 2grand maybe a little more i noticed if i pinch the return line with my finger it drops the idle about 500 any of you guys running these motors ever have a high idle issue and and if you have a tach where about is yours idleing thanks
 Post subject: Re: high idle
PostPosted: Tue Jan 25, 2011 10:35 pm
we did a suby swap and it had an idle problem and im pretty sure it was a problem between the pvc plumbing and air to the idle air control
PostPosted: Tue Jan 25, 2011 10:56 pm
Mine idles right at 600 rpm, I suspect you have a vacuum leak, spray some wd40 around intake,vacuum hoses, etc to see if you can find it.
PostPosted: Wed Jan 26, 2011 1:24 pm
i will try what both you say i looked at my hose for my mass air flow sensor it is loose where i put sealer around it and i will also check for vaccuum leaks thanks guys
PostPosted: Wed Jan 26, 2011 3:30 pm
Idle bypass valve :mrgreen:
