| Hyabusa engine in stalker. http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=10996 |
| Author: | Stevo [ Fri Jan 07, 2011 10:04 pm ] |
| Post subject: | Hyabusa engine in stalker. |
Do you think it would be worth it? I was thinking bout pulling suby to put busa in. I was thinkin light weight and one awsome sound at 12,000 rpm. Somthing like this.... but in a woodsbuggy http://www.youtube.com/watch?v=qoGGNuk6 ... re=related |
| Author: | JeffClay [ Fri Jan 07, 2011 10:23 pm ] |
| Post subject: | Re: Hyabusa engine in stalker. |
DO IT! |
| Author: | bmoore [ Fri Jan 07, 2011 10:42 pm ] |
i dont see why it wouldnt work |
| Author: | Stevo [ Fri Jan 07, 2011 10:43 pm ] |
I need a gearbox with reverse to go to the cvs. I just might try it. |
| Author: | bmoore [ Fri Jan 07, 2011 10:52 pm ] |
SubySteve wrote: I need a gearbox with reverse to go to the cvs. I just might try it. id like to see you do it |
| Author: | Maddog [ Sat Jan 08, 2011 1:55 am ] |
I think that any low end torque would be lacking. |
| Author: | instigator [ Sat Jan 08, 2011 2:06 am ] |
here look at this. http://kansascity.craigslist.org/rvs/2097151967.html |
| Author: | bmoore [ Sat Jan 08, 2011 2:12 am ] |
instigator wrote: here look at this. http://kansascity.craigslist.org/rvs/2097151967.html now that is cool! id like to know how its all mated together |
| Author: | Odyknuck [ Sat Jan 08, 2011 7:47 am ] |
The drive line on that type of Buggy is similar to my Pilots. It uses an RPM gearbox ($2500.00) coupled to a CVT setup off of a Snowmobile. Not really the best setup for crawling around the Woods of Wellsville in your car, its to heavy IMHO. Would be a good Woods setup in a mid size chassis less than 900#. Half way between a Pilot and and a standard size buggy. BTW the Blonde is the owners wife. He is a member of Minibuggy.net |
| Author: | ImmortalSoul219 [ Sat Jan 08, 2011 12:45 pm ] |
I thought about a street bike engine buggy too but dont think it wouuld be ideal. The engines arent cheap. They are higher maintence. The power band isnt ideal. Theres lots of power but torques weak. Weight has to be low. The engines are ment for a light motorcycle n when you put them in a heavy buggy the engines wear out alot faster. Would be cool but no way its better then an Ecotec! lol |
| Author: | chopper [ Sun Jan 09, 2011 1:23 pm ] |
Ive got a 2007 Yamaha R1 Engine....fuel injected!!!!!...low miles too.....$500.00 buys it!....all wiring and ecu |
| Author: | Stevo [ Mon Jan 10, 2011 6:29 pm ] |
chopper wrote: Ive got a 2007 Yamaha R1 Engine....fuel injected!!!!!...low miles too.....$500.00 buys it!....all wiring and ecu |
| Author: | wheelieup [ Mon Jan 10, 2011 6:53 pm ] |
i think id rather ride her around instead. |
| Author: | kevin f [ Sun Jan 30, 2011 11:28 pm ] |
Ive got a freind that owns a motorcycle junk yard here in alabama. he has a 1200cc motor that was run in a dwarf car. he is wanting to put it in a buggy. I think it would be bad ass. The only problem is finding a combination with reverse. |
| Author: | tw9294 [ Tue Feb 01, 2011 9:52 pm ] |
Maddog wrote: I think that any low end torque would be lacking. This 166 inch s&s should be tourqy
