 Post subject: subaru adapter question
PostPosted: Sat Jan 01, 2011 2:33 pm
i am getting ready to order a adapter kit as soon as i found out what i am asking about ive got a 94 subaru legacy 2.2 i am wanting to hook up to a 6 rib nose cone shift tranny my question is what would this be, a subarru to type 1 transmission or what :?:
PostPosted: Sat Jan 01, 2011 3:44 pm
Just tell them what you are running,,,the bell housings have the same bolt pattern for type 1, 2, and 091 (6rib)
PostPosted: Sat Jan 01, 2011 4:53 pm
ok thank you
PostPosted: Sat Jan 01, 2011 10:18 pm
kennedy will take care of you! and they dont mind takeing the time to answer any question you may have :wink:
lets just ride
PostPosted: Thu Jan 06, 2011 6:40 pm
ok here is another question 200mm or 225mm bore what should i get, here is what i plan on running clutch wise a stock clutch with a stage 2 pressure plate motor will be bolted to a 6 rib transmission which of these would you suggest for what i will be using as described
k.a.p asked this question to me and i was not sure
PostPosted: Thu Jan 06, 2011 7:19 pm
The 225 will be a stronger clutch setup, but will also weigh more.
I'd probably go with the 200 because of that in a buggy.
The heavier clutch&flywheel assembly will make the engine rev slower and will be harder on the tranny if you drop the clutch.
PostPosted: Thu Jan 06, 2011 8:03 pm
:idea: :|
PostPosted: Thu Jan 06, 2011 8:08 pm
passat2800 wrote:
:idea: :|
are you jehovah witness :?: :twisted: :?: :twisted:
lets just ride
PostPosted: Fri Jan 07, 2011 12:34 pm
the 200mm would be cheaper in the long run too!
PostPosted: Sun Jan 09, 2011 11:23 pm
thanks we ordered the 200mm now just have a 2 1/2 week wait for some reason all is good though still gives us a few months to do it
