 Post subject: Motor Mounts???
PostPosted: Fri Dec 10, 2010 11:36 am
Hopefully bolting my new Subaru up soon... Should I run motor mounts ( I was guessing YES) ??? If so do they need to be anything special or just solid mounts that come off the frame??? Thanks.
 Post subject: Re: Motor Mounts???
PostPosted: Fri Dec 10, 2010 11:55 am
My bellhousing is mounted top ears and bottom, no motor mounts.
No problems for 8 yrs.
PostPosted: Fri Dec 10, 2010 11:58 am
Some folk use motor mounts, some don't. I didn't on my last build and I'm thinking on using them on this build. I didn't have any problems not having them, just cheep insurance. All it needs to be is a solid mount if everything is solid mounted.
PostPosted: Fri Dec 10, 2010 6:28 pm
I supported the wishbone to the frame at the ends near the engine..was fine for the 4 cylinder..when I went to a 6 banger I made some motor mounts at the factory location on the suby,,kinda hanger style.
PostPosted: Sun Dec 12, 2010 2:02 am
I made a solid mount that I welded to the stock motor mount plates.
PostPosted: Sun Dec 12, 2010 10:14 am
Run a pair to the rear half cage on ours, we cracked a bellhousing back on the old VW so not risking it with the rotary.
PostPosted: Sun Dec 12, 2010 12:06 pm
That looks easy enough. I am using all four mounting points on my bellhousing as well so I don't think it will go anywhere. Thanks for the suggestions.
PostPosted: Sun Dec 12, 2010 6:51 pm
at first i didnt run any motor mounts with my new suby! but the suby broke the front trans mount :| so this weekend i repaired tranny mount and fabed up some solid motor mounts :wink:
lets just ride
