| Suby oil pan http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=10590 |
| Author: | ehale [ Fri Oct 29, 2010 1:37 pm ] |
| Post subject: | Suby oil pan |
How much do I need to cut my oil pan on my suby and what is everyone doing with the oil filter? |
| Author: | Firebug [ Fri Oct 29, 2010 5:00 pm ] |
| Post subject: | Re: Suby oil pan |
I cut mine down to 3 1/4" total and use a remote filter. |
| Author: | bmoore [ Fri Oct 29, 2010 7:02 pm ] |
small car performance sells a nice aluim one but its high, i bought one it is lower profile and still alows you to run 5 quarts of oil without looseing any ground clearence |
| Author: | ehale [ Fri Oct 29, 2010 8:20 pm ] |
Firebug wrote: I cut mine down to 3 1/4" total and use a remote filter. how much oil does it hold now and did you take the baffle out of the pan or whatever its called |
| Author: | bmoore [ Fri Oct 29, 2010 8:21 pm ] |
ehale wrote: Firebug wrote: I cut mine down to 3 1/4" total and use a remote filter. how much oil does it hold now and did you take the baffle out of the pan or whatever its called it will hold 5 if u run a remote filter |
| Author: | Stevo [ Fri Oct 29, 2010 8:26 pm ] |
I cut mine at 4in and left the filter where it belongs. |
| Author: | bmoore [ Fri Oct 29, 2010 8:38 pm ] |
i think marty ran the stock filter and a remote to get his 5 quarts |
| Author: | Firebug [ Fri Oct 29, 2010 8:56 pm ] |
I still ran 5 qts but it measured a little high on the dipstick. I run a remote filter to get it up higher,,away from the skid pan, and to run a much bigger filter. |
| Author: | MadMike [ Fri Oct 29, 2010 11:22 pm ] |
I cut mine off at 4" from the rail. Holds 4 quarts of oil with a stock filter, no issues. |
| Author: | volksdude2007 [ Sat Oct 30, 2010 1:33 am ] |
i cut mine at 4" took that plate out of the inside of the pan and welded on the inside of the pan also dont leak a drop and still use a stock filter it is right at the skid plate on mine almost butting up to each other wish i would have taken it to 3 1/2" but every skid plate is probably set diff |
