It is currently Mon May 04, 2026 1:04 pm
 Post subject: which one to buy
PostPosted: Fri Oct 22, 2010 9:12 pm
I called a couple of salvage yards looking for a 2.2 Subaru and they said that the engine with a manual transmission is different than one with a automatic. So what do I need to ask for? I am new to the suby thing and don't have a clue. Any advice would be helpful.
 Post subject: Re: which one to buy
PostPosted: Fri Oct 22, 2010 9:26 pm
mine is out of a automatic, and nothing diff about the engine, either one is fine, the wireing harness maybe different but your harness has to be wired anyway, firebug did my wireing harness
lets just ride
PostPosted: Fri Oct 22, 2010 10:26 pm
somewhere I read that the manual is preferred for the harness and sensors,, but I dont think it matters all that much,,,all my 3.3 engines are auto.I can help you do a obd1 harness.
PostPosted: Fri Oct 22, 2010 10:41 pm
from what iv seen they are the same i was told the manual has a timming belt guide to help it not jump timming in hight rpm free revs my 2.2 was an auto also
PostPosted: Sat Oct 23, 2010 4:30 pm
newer cars (2000ish+) did have the timing belt guide, and a different EGR setup. and wiring is a bit different.
in the '90-94 OBD I ones though. Engine and ECU are identical. wiring is only a little different.
