| suby 2.2??? http://woodsbuggy.com/phpBB3/viewtopic.php?f=17&t=10383 |
| Author: | bmoore [ Wed Sep 29, 2010 8:40 pm ] |
| Post subject: | suby 2.2??? |
which fuel line is supply and which is return? |
| Author: | kybuggy1 [ Wed Sep 29, 2010 8:42 pm ] |
| Post subject: | Re: suby 2.2??? |
The one that smells like rice is the supply. J/K ! Glad to see you back into it. Hurry up , tho!! |
| Author: | bmoore [ Wed Sep 29, 2010 8:46 pm ] |
kybuggy1 wrote: The one that smells like rice is the supply. J/K ! Glad to see you back into it. Hurry up , tho!! lmao |
| Author: | Firebug [ Wed Sep 29, 2010 8:55 pm ] |
The higher one is for the pressure. |
| Author: | bmoore [ Wed Sep 29, 2010 8:56 pm ] |
thanks marty! |
| Author: | numbchux [ Thu Sep 30, 2010 4:11 pm ] |
I believe that's correct. If you trace the lines, the one that goes straight to the injectors is the supply, and the one coming from the pressure regulator is the return. |
| Author: | bmoore [ Thu Sep 30, 2010 9:49 pm ] |
numbchux wrote: I believe that's correct. If you trace the lines, the one that goes straight to the injectors is the supply, and the one coming from the pressure regulator is the return. thanks for the input, it was the top one and she is purrin now |
| Author: | bmoore [ Sat Oct 02, 2010 4:57 pm ] |
what have u suby guys been doing for a water temp guage? and were are you putting the sending unit??? |
| Author: | nitro_mudder [ Sat Oct 02, 2010 5:02 pm ] |
Mine is plumbed in the line to the radiator. A small sensor put into a Galvonized t-fitting with some reducers. seems to work, lol. Hey, at least there is a guage! |
| Author: | Firebug [ Sat Oct 02, 2010 5:55 pm ] |
I do not have a temp gauge,,or oil pressure , or any gauge at all. |
| Author: | bmoore [ Sat Oct 02, 2010 6:06 pm ] |
Firebug wrote: I do not have a temp gauge,,or oil pressure , or any gauge at all. just ride off the hill gods good intentions huh? i like it |
| Author: | Stevo [ Sun Oct 03, 2010 8:04 pm ] |
I boght one from summit with temp, oil,voltage, and tach all in one. 149 bucs. http://www.summitracing.com/parts/SUM-800104/ |
| Author: | bmoore [ Sun Oct 03, 2010 9:04 pm ] |
SubySteve wrote: I boght one from summit with temp, oil,voltage, and tach all in one. 149 bucs. http://www.summitracing.com/parts/SUM-800104/ thanks subysteve. which port did you use in the water system? |
| Author: | bmoore [ Fri Oct 22, 2010 11:46 pm ] |
SubySteve wrote: I boght one from summit with temp, oil,voltage, and tach all in one. 149 bucs. http://www.summitracing.com/parts/SUM-800104/ installed this guage yesterday and it works great |
