It is currently Sat May 02, 2026 5:57 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Suby build
PostPosted: Thu May 22, 2014 3:45 pm
not much to see in a video yet. I will video it on the dyno!
PostPosted: Mon Jun 09, 2014 8:56 am
Now that I have it running, its time to built a new intake! I found a inexpensive ITB (individual throttle body) intake made to fit under the hood of a Subaru. I can use the throttle bodies and make my own intake.
48 mm for each runner
some fancy long velocity stacks
PostPosted: Mon Jul 21, 2014 8:29 am
Got back at it again this weekend. had to finish fabbing up velocity stacks and had to remachine just about everything on these throttle bodies from injector ports to fuel rails.
making the air box
mount and plumb up air filter
my youngest wanted a welder ride!
PostPosted: Mon Jul 21, 2014 8:37 am
Nice job on the youngest.Fab work ain't bad either
PostPosted: Mon Jul 21, 2014 2:54 pm
Thanks rock! im itchin to get this thing done already!!
PostPosted: Thu Jul 24, 2014 11:06 am
I have spent the past 3 days trying to get the throttle blades to seal up by sanding away by hand little by little. The lowest it will idle is about 1800 rpm. just cheap Chinese castings!
PostPosted: Thu Sep 25, 2014 8:15 am
spent 6-7 hours on the dyno yesterday. Not thrilled with the numbers, but he says his dyno is stingy. He figures it should be around 220-230HP at the flywheel. It does better than a stock WRX on that dyno. Not bad for NA.
https://www.facebook.com/video.php?v=10152753064838428
PostPosted: Thu Sep 25, 2014 9:05 am
That's not far off what we had with the rotary, and that had plenty enough grunt to be fun - when it wasn't blowing up. :lol:
PostPosted: Fri Sep 26, 2014 8:38 pm
RaceBugg1098 wrote:
Rick wrote:
Talk about not rushing into anything :roll:
hahaha, funny guy!
kevins port job
3 angle valve job
stock piston and custom ross piston
PostPosted: Fri Sep 26, 2014 8:40 pm
RaceBugg1098 wrote:
we got around to measuring all the oil clearences this weekend at sattlers dyno shop.
.0025 for the rods and .0035 for the mains
and we honed the wrist pin holes on the rods and pistons
and balanced the pistons
time to get the bottom end bolted up!
PostPosted: Fri Sep 26, 2014 8:42 pm
That's sweet! It's got to be relieving to not just walk past all the projects on the bench. I need to get motivated and get some things done on mine (not as bad ass though)!!
PostPosted: Mon Sep 29, 2014 7:23 am
yes it is nice to have that out of the way. it only took 3 years :roll:
