It is currently Sun May 03, 2026 5:30 am
Post new topic Reply to topic  [ 187 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: Donor car
PostPosted: Sat Jan 17, 2009 12:23 am
Odyknuck wrote:
Something to keep in mind when extending the rear section. The farther you get behind the the wheels the steeper the approche angle. Meaning you have less clearence to drag going from flat ground up a hill and visa versa. You essentially lose ground clearence. Food for thought.
"Baby chains" already set his wheels way back....an extra 4.5" should be ok 8)
Mike
Got Honda?
PostPosted: Sat Jan 17, 2009 10:00 am
Valid point
PostPosted: Sat Jan 17, 2009 6:30 pm
Griffin came by and helped me a lot. Here it is ,,don't seem to hang out the back too far with 35's, thanks to Babychains
PostPosted: Sat Jan 17, 2009 6:40 pm
looks really good bug -- now you get to see how much more power you got
PostPosted: Sat Jan 17, 2009 9:50 pm
Bug from where I sit it looks like a killer combo the weight looks distributed well ,Man I can't wait to see it run :!:
PostPosted: Sat Jan 17, 2009 11:04 pm
Now that I see it together and on the ground You will not have anb issue. Looking good and coming together.
PostPosted: Sun Jan 18, 2009 1:22 am
Glad I could help. Looks like it turned out really good. I think I'm out of 3/4 .120 wall tubing. I only had a little bit left and I think I let a buddy of mine have the rest of it cause he needed it to finish up something. I already have some more on order so it should be here this week.
John
PostPosted: Sun Jan 18, 2009 10:16 am
Hey bug did you have to change the whole wire harness? Looks good cant wait to hear it.
PostPosted: Sun Jan 18, 2009 10:22 am
I am changing the harness. The eg33 is very similar to the ej22 but different. I am using a speed sensor simulator from enginewiring.com this time. One less thing outside the ammo box. I made a speed sensor for the ej22. I understand some ej22's don't absolutely need the speed sensor but mine did idle better with it. I wll hold off till the end to put the harness on. Easier to route small wires than hoses, cables, bracing,,etc.
PostPosted: Sun Jan 18, 2009 8:46 pm
What is the simulator? Is it just a voltage divider to trick the ECU? Or Is it a electronic pulse generator. What did he charge you for it?
PostPosted: Sun Jan 18, 2009 8:48 pm
It just tricks the ECM. Here is a link,,,it's $40 shipped. I probably had close to that in my home made setup
http://enginewiring.com/Products.html
PostPosted: Mon Jan 19, 2009 1:02 pm
better view
PostPosted: Mon Jan 19, 2009 1:51 pm
So what did your homemade setup consist of.
PostPosted: Mon Jan 19, 2009 9:19 pm
I made a sensor using a hall effect switch exactly like this
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... :IT&ih=017
and magnets like these
http://cgi.ebay.com/20-Neodymium-Magnet ... 1|294%3A50
I used 4" schedule 40 pvc ( is this correct,,Plumber Bill? the thick stuff) I'm pretty sure about this use apporximate 1.5" section of 4" schedule 40 and a 1.5" section of like size coupler with the 3 or 4 magnets, I used 3 because it's easy to space them by the cv bolt holes :wink: . These sizes are for putting on a 930 cv.. Here is a pic of a set unfinished and the one I just removed from the ej22. Notice they are cut, this aids in putting them over the axle and it also makes them fit the 930 cv snuggly. Drill the holes in the coupler for the magnets and epoxy them in after you glue the other 2 sections together with the slits lined up.. Then make a bracket to hold the hall effect switch about a quarter inch off the magnets , I bolted mine with one of the starter bolts.
PostPosted: Mon Jan 19, 2009 9:29 pm
Here is the motor mount roughed in,,I ran out of welding gas so it will be tomorrow before I get them finished
PostPosted: Mon Jan 19, 2009 10:05 pm
Hey Bug looks good. Ive been thinking ( yes that could be why you smell smoke ) I think that all this high tech enginuity would look better if you had it on a new frame. Hint Hint
PostPosted: Mon Jan 19, 2009 11:03 pm
I do like your frame,, How much? just kidding,, I ain't got no money :oops: It would look good with babychains :wink:
PostPosted: Mon Jan 19, 2009 11:19 pm
Think of it like this bug , you're sooooooo close to gettin it the way you want it -- with a new frame you'd have to start over!!!!!!!!!! :roll:
PostPosted: Tue Jan 20, 2009 10:02 pm
What happened to putting the motor mounts aside and doing other things with the project while I built your mounts? I've already cut them out and drilled the tubing for the sleeves.
John
PostPosted: Tue Jan 20, 2009 11:06 pm
I forgot :oops:
PostPosted: Mon Feb 09, 2009 11:21 pm
The SVX had a tension pulley for the belt but I modified the bracket and use the alternator to tension the belt now
PostPosted: Mon Feb 09, 2009 11:23 pm
I moved the radiator forward a couple inches to allow the air tube to fit the throttle body. And got the radiator plumbed.
PostPosted: Tue Feb 10, 2009 1:23 am
Lookin good Marty!
PostPosted: Tue Feb 10, 2009 11:55 am
Won't be long. I still want to see those boggers spinning at 120mph :)
"Lets go get stupid"
PostPosted: Tue Feb 10, 2009 7:55 pm
I like the way it looks with 35" boggers but mine are only 10.50 wide. Any wider is gonna be pretty heavy. The 33's look good but not enough height gain to justify leaving the V-treads. Is there a V-tread in a 33 but not as wide as the 15.50's so as not to gain too much weight?,,I know I'm rambling,,just thinking out loud. I want to try some wider boggers but I don't want to brake trannys. Who knows,,with the extra weight and power the 35X10.50's may be fine :?
