It is currently Sun May 03, 2026 4:15 am
 Post subject: its time for a change
PostPosted: Sun Dec 28, 2008 5:21 pm
well i went and got a suby motor today it wont be going in till next winter probably when i get my new frame and adapter plates but where do you guys get your adapters and what does the crank sensor run or does anyone have a spare one lying around they would like to sell im excited to see what this motor will do
thanks
Roy
PostPosted: Sun Dec 28, 2008 5:24 pm
Which suby engine did you get? I got my adapter from Kennedy Engineering Products. Small Cars bell housing looks good.
PostPosted: Sun Dec 28, 2008 5:27 pm
its a 1990 legacy 2.2 got it off the guy who had two for sale on the parts for sale forum also what horsepower can i be looking at with a motor like this from a 1915
PostPosted: Sun Dec 28, 2008 6:15 pm
Kennedy is the place to get your adaptor plate they also provide wiring information for the Subie/ VW swap. I got my clutch and p/plate from them as well.
I had mine on a chassis dynometer a couple of years ago. It ran 121 ftlb 100 hp at the wheels.
What trans are you planning to use?
I can hook you up on wiring info if you need it.
PostPosted: Sun Dec 28, 2008 6:28 pm
i have a 5 rib tranny and is this motor much different than my 1915 hp wise
PostPosted: Sun Dec 28, 2008 6:39 pm
I'm only guessing bout the HP,,but I would say close to the 1915. What tires you running,,,my rev limiter does not come in hardly any with 456 and 31's,,your 482 with ej22 might come in with 31's when you stick your foot in it on long hills or drag races.
PostPosted: Sun Dec 28, 2008 7:06 pm
i run 31's i thought the suby would have a good bit more power than the vw but at least it will be less maintnance
PostPosted: Sun Dec 28, 2008 7:20 pm
Welcome to the darkside my friend.
PostPosted: Sun Dec 28, 2008 7:22 pm
Don't take my word on the HP,,My buggy is heavy,,,real heavy. I know I like it a lot with the ej22. I am sure you will like the ej22 too.
PostPosted: Sun Dec 28, 2008 7:25 pm
Can't answer that for sure. What I can tell you is you'll notice a big differance. Also worth noting SubieSteve had a 2070, a damn good running 2070 before his swap, it's safe to say we all know what he thinks about the power differance.
Rev limiter ?? Hell I'm on a first name basis with it.
My 6 rib is stuffed with Wedle parts, not so cheap insurance. Keeps me behind the wheel instead of wrenching all the time.
I opted for 930 CV's again not so cheap insurance, for the same reason.
SubieSteve is having good luck with type 2/4 CV's and I know PlumberBill has 930 stuff.
You will be the 6th Subie powered car at Wellsville that I know of so far.
PostPosted: Sun Dec 28, 2008 10:30 pm
:shock: :twisted: I guess everybody is joining the Dark Side for the 2009 season! :twisted: :shock:
PostPosted: Sun Dec 28, 2008 10:45 pm
cool about the outcome for noticing the difference now all i have too do is cross my fingers and hope i can get all the wiring figured out and oil pan cut correctly if any one can post some pics of their oil pans or how much they cut off and what tubes and stuff i can get rid of i took the ac pump and power steering pump off so far because i deffinetley dont need those but any help on elimintating the extra hoses and pipes id appriciate it
PostPosted: Sun Dec 28, 2008 10:54 pm
If your not going to use the power steering pump, I can use it. I can help ya out with oil pan, cut it down to 4 inches tall.
PostPosted: Sun Dec 28, 2008 11:09 pm
you want it you can have it its no use to me
PostPosted: Mon Dec 29, 2008 10:53 pm
steve let me know on the power steering pump and i can drop it off or somethin someday after work i work at penn power in zeli so it wouldnt be out of my way
PostPosted: Mon Dec 29, 2008 10:56 pm
Thanks Roy, the pan in the pic will off soon to put a new one on. Youll be able to take a look at the pan and pic up.
