It is currently Mon May 04, 2026 1:05 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Sep 14, 2013 11:38 am
2800passat wrote:
I will never go water cooled again with a heavy water cooled motor unless at least a foot of baby chains was added. It makes ALL the difference ! gearing, center of gravity, and some added hiegth.But narrow is very important too because too wide will make the buggy pull lt n rt depending on which side is biting, and there is not enough side to side room on most hill climbs. Sometimes you will be so wide that you HAVE to hit an obstical coming at you.
If you build the chassis yourself you can adjust the center of gravity to account for a heavier engine in the rear. The cars I owned previous to my limo were cab forward designs which shifted the center of gravity forward. So the heavy engine thing can be accounted for
PostPosted: Sat Sep 14, 2013 11:49 am
My next contraption has a 4 cyl. Honda V tec automatic sitting exactly where a vw ac goes but sideways. then some short chains that connect to the existing inner c/v joints.Gear reduction with an automatic.nice!!
PostPosted: Mon Sep 16, 2013 8:45 pm
Sorry passat have to totally disagree with you. I think I finally have the gearing and weight distribution figured out. You don't need baby chains or turning the motor sideways to get it to work. Just proper weight positioning, the right gear for the hp, some longer trailing arms, the right driver and it works. And I know a couple 2 seat na ecotec buggies that do awesome. I honestly believe my buggy will compete with some of the baddest ac buggies out there now. With the right driver
PostPosted: Thu Sep 19, 2013 11:01 pm
The 2.4 LE5 Ecotec weighs in at 278 lbs fully dressed.
If you're looking for fantastic P/W ratios - check out the 2.0/2.2/2.4.
Shaun
PostPosted: Fri Sep 20, 2013 9:35 am
I roughly weighed the sc 2.0 and it weighed a bit more than that BUT!!!!!! I AGREE WITH TERRY i believe you can get the balence by building the chassis around the motor.my biggest question is if the tranny will hold up to my heavy right foot.we`ll see next year.
PostPosted: Fri Sep 20, 2013 6:34 pm
Pretty much this, most of your american buggies have HUUUGE arses.
I was going to draw a comparison but I can't think of one....honest :wink: :lol:
PostPosted: Fri Sep 20, 2013 10:23 pm
What, exactly are you trying to say PhillipM? All of us Yanks have fat asses?
PostPosted: Sat Sep 21, 2013 12:06 pm
Extra seat padding? :lol:
