It is currently Sun May 03, 2026 3:34 pm
 Post subject: need ecotec help
PostPosted: Sun Apr 03, 2011 8:16 pm
I started my motor for the first time 2 weeks ago. Then again today it was running good I let it get up to temp (idle for about 20 mins) turned it off let it cool. then started it again this time a reved on it some 3k 4 or 5 times then 5k but when it came down it idled a few sec then stoped.
So looking at everything it has no code. i pulled the fuel rail turned it over fuel was good. pulled the coil put plugs in turned it over and no fire so could it be it was just its time to die and i need a coil(anyone know how to see if one is good :?: )i put a Multimeter to the plug going to the coil and turned it over a few volts at each
any ideas would help thanks
 Post subject: Re: need ecotec help
PostPosted: Mon Apr 04, 2011 6:38 pm
Your saying when the rpm came down that it shut off instead of idle correct?
check your idle valve give it a good cleaning.
PostPosted: Mon Apr 04, 2011 8:54 pm
No its did not idle at all it it hit 5k cut out some and know it will not start and it has no fire at the plugs.
Im thinking its the Ignition Control Module but dont know does this sound right?
PostPosted: Mon Apr 04, 2011 8:58 pm
So you have no spark. coil pack probably bad. Got anyone you could swap out just too test it? Maybe a junk yard trip? Buddy had this problem. Got one of the junk yard for $30 n started right up. Not sure though how to bench test.
PostPosted: Mon Apr 04, 2011 9:39 pm
thats what im thinking but do they just go bad like that
btw the motor has been seting since feb of 2008 till I started it 2 weeks ago
PostPosted: Mon Apr 04, 2011 9:41 pm
coil packs r common on ecotecs sell them all the time
PostPosted: Mon Apr 04, 2011 10:09 pm
I just checked the oms over the coils 1-4 is 4.07 and over 2-3 is 4.07 so im thinking it the Ignition Control Module that sets on the coils anyone have one go out before.
PostPosted: Mon Apr 04, 2011 10:32 pm
Being all freshly installed i'd check power and grounds to the module before buying parts. Maybe you already did. :?: My car quit running shortly after i finished my swap and it was just a poorly crimped terminal on a wire to the fuel pump relay.
PostPosted: Tue Apr 05, 2011 4:45 am
I agree with you tw I would go back and run continuity on all my wires and double check your crank sensor
plug and wires. If they are grounding out it will do that.
PostPosted: Tue Apr 05, 2011 7:10 am
yup I just got the whole coil pack assembly cheap from the junk yard n it fired right up.
PostPosted: Sun Apr 10, 2011 9:19 pm
you all must of been right I wire everything in for good and fired right up now i cant wait to get done and go for a ride :D
PostPosted: Mon Apr 11, 2011 6:33 pm
so it was probably just a bad ground then?
PostPosted: Mon Apr 11, 2011 6:45 pm
i really dont know for sure but im thinking so
