It is currently Mon May 04, 2026 5:29 am
 Post subject: Starters
PostPosted: Sun Jan 30, 2011 12:46 pm
Im going to be running a ecotec with a 6rib and need a starter.
So what starter are you guys running on your ecotec's??
I have been thinking about milling the bell down to run a Firebug style starter :wink:
Will a stock 091 starter start it??
Thanks
 Post subject: Re: Starters
PostPosted: Sun Jan 30, 2011 1:27 pm
stock 091 will work fine. buddy has one on his for over a year now
PostPosted: Mon Jan 31, 2011 6:41 pm
Firebug has 1 for sale, the type he uses is the best I know of including those aftermarket hi-torque starters.
PostPosted: Tue Feb 01, 2011 9:38 pm
i tried a brand new stock 091 starter and it turns too slow. It did start it but barely. I put one of the high tourqe starters on and it wizzes right over.
PostPosted: Tue Feb 01, 2011 9:50 pm
Thanks im planning on getting the high tourqe starter :D
PostPosted: Tue Feb 01, 2011 10:58 pm
I didnt forget 8) :lol: here is a link for an adapter for a TDI starter.
http://www.thesamba.com/vw/classifieds/ ... ?id=694797
PostPosted: Wed Feb 02, 2011 11:36 pm
THANKS dave 8)
Im ordering one looks like it would work really good!!
PostPosted: Fri Feb 11, 2011 7:50 pm
Has anyone tried this
I ordered one and the starter but the starter firebug uses is a 9 tooth this one calls for a 10 tooth just wanted to see if anyone has one
PostPosted: Fri Feb 11, 2011 10:07 pm
That adapter is a great idea,,then you still have your warantee on the starter. The ones I convert are altered and the waranty may not be good. I imagine the number of teeth is important and it should turn CCW . I am interested in hearing about the 10 tooth starter.
PostPosted: Fri Feb 11, 2011 10:12 pm
It does go ccw. i should have it monday so i will post some pics
PostPosted: Fri Feb 11, 2011 10:16 pm
$60 bucks aint bad,,those starters are wicked strong,,,maybe our resident machinist can duplicate them ,,,hear me MadMike?????
PostPosted: Fri Feb 11, 2011 10:34 pm
me and another guy aready run them i have a factory tdi starter on my 2387 11.5 to 1 compression works awesome in my opinion they have twice the speed and torque of a imi high torque starter
the other guy has one of the starters from ebay ( i have one too a spare ) he has no complains about it either i think i have some adapters already made ill check tommorrow if u guys want one pm me and well see what we can work out
PostPosted: Sat Feb 12, 2011 5:39 pm
got my starter today here is a side by side with the one from my 3 rib the drive gear is bigger being 10 tooth but the teeth are the same on both
