It is currently Sun May 03, 2026 11:01 am
 Post subject: Ios7 problems
PostPosted: Fri Sep 27, 2013 8:59 pm
Anyone else update their iPhone to the new update and having crash problems with the app?
 Post subject: Re: Ios7 problems
PostPosted: Fri Sep 27, 2013 9:28 pm
Crashes nonstop unless I have wifi
PostPosted: Fri Sep 27, 2013 10:17 pm
I did a lot of testing on IOS7 before it was released and did not have any issues.. I tested an iPad2, iphone4, iPhone 4S and iPhone 5. The only issue I ever had was the iPhone4. IOS7 runs really slow on an iphone4 and you have to close applications you are not using. If you have too many apps opens, lots of random bad things can happen.
Although I did not have any issues, I will check around and see if there any new issues with IO7
PostPosted: Fri Sep 27, 2013 11:10 pm
It appears that there is a bug in the app when you are using a cellular connection. Still working to find out the cause. It works fine on a Wifi connection. More to come..
PostPosted: Fri Sep 27, 2013 11:47 pm
Thanks mickeymouse.
PostPosted: Sat Sep 28, 2013 3:22 pm
I love the new iso7 I've had now issues.
