| bus swing axel? http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=9942 |
| Author: | hcoabel [ Thu Jul 22, 2010 5:22 pm ] |
| Post subject: | bus swing axel? |
Bought a new frame and it has a swing axel in the real with a car tranny, I'm wanting to put this 3 rib I have in it but can I keep the swing axel? |
| Author: | Maddog [ Thu Jul 22, 2010 7:31 pm ] |
| Post subject: | Re: bus swing axel? |
Nope, you'll have to change or convert the torsion to irs. |
| Author: | chris38375 [ Thu Jul 22, 2010 7:34 pm ] |
i have seen a car one time that welded on the pivot for the trailing arms and cut his spring plates jus like the irs spring plates,its alot easier fix |
| Author: | hcoabel [ Thu Jul 22, 2010 7:36 pm ] |
Trying to do it as cheap and as durable as possible just had twins so tight budget, I also think it is an aftermarket kit because it does not look like a stock swing setup |
| Author: | perrib [ Sat Jul 24, 2010 7:08 am ] |
Pictures? |
| Author: | hcoabel [ Wed Aug 04, 2010 1:19 pm ] |
| Author: | perrib [ Wed Aug 04, 2010 2:14 pm ] |
To install the 3 rib T-2 transaxle you will need T-1 rear arms, swing to IRS conversion brackets, VW Thing or conversion axles, adjustable shift rod end, four T-4/T-2 cv joints and purchase or fabricate transaxle mounts. For my conversion I cut out the swing torsion housing and welded in an IRS torsion housing I had. The parts in the pictures you posted appear stock. Post some pictures of the spring plate /brake assembly. |
| Author: | hcoabel [ Sat Aug 14, 2010 3:29 pm ] |
http://i904.photobucket.com/albums/ac24 ... 8543bb.jpg http://i904.photobucket.com/albums/ac24 ... 61c111.jpg |
| Author: | hcoabel [ Sat Aug 14, 2010 3:32 pm ] |
| Author: | perrib [ Sat Aug 14, 2010 10:46 pm ] |
Thats a typical T-1 swingaxle transaxle. |
| Author: | hcoabel [ Sun Aug 15, 2010 1:10 pm ] |
So how do I convert this to an irs setup, pretty sure I need new trailing arms etc... and I'm trying to do it on a budget but I still want to do this right |
| Author: | perrib [ Sun Aug 15, 2010 2:33 pm ] |
Easiest way is with a donor VW so you can cut the torsion housing out off and have all the diagonal arm parts, axles, nuts, bolts and IRS tranaxle. There are two menber here who have found or are selling $350-$500 Bugs. I don't know about where you live but in Phoenix good T-1 swingaxle cores bring $125.00. Pans with titles $100-$200 so parting one out afterwards really lowers your final cost. On more than one car I sold the left over parts for more than what I paid. |
