091 gear oil
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=9673
Author:  MickeyMouse [ Sat Jun 12, 2010 6:04 pm ]
Post subject:  091 gear oil
What kind of gear oil do you recommend for the Tranny?
Author:  kybuggy1 [ Sat Jun 12, 2010 6:45 pm ]
Post subject:  Re: 091 gear oil
85w90. NON synthetic. Dont know if any one brand is better than another. Chuck says it doesnt matter, just change it every year or so.
Author:  Maddog [ Sat Jun 12, 2010 7:31 pm ]
Swepco 203 from pelicanparts.com, I really believe in it.Image
Author:  MickeyMouse [ Sat Jun 12, 2010 8:19 pm ]
Thanks...
Author:  rockrockets1 [ Sun Jun 13, 2010 9:12 pm ]
Why non synthetic :?:
Author:  tw9294 [ Sun Jun 13, 2010 9:47 pm ]
Yeah why not?
Author:  kybuggy1 [ Sun Jun 13, 2010 10:19 pm ]
Thats what Chuck told me when I asked what to put in mine. Dont know why. Whatvr he says about a tranny, its correct. No explanation needed for me.
Author:  Odyknuck [ Sun Jun 13, 2010 11:10 pm ]
I would agree to not use Synthetic to break in a trans, however I see know reason not to run it after break in. That is odd that he would say that. I would really like to know why.
Author:  RaceBugg1098 [ Mon Jun 14, 2010 7:54 am ]
the synthetic is too slippery! The syncros want some friction and is you just run synthetic you can notice the gears grind a little when shifting. I even squirt a little moly grease into my tranny to help it shift smoother
Author:  Odyknuck [ Mon Jun 14, 2010 10:20 am ]
I was running a syn/straight. Now I am running straight because thats all they had at the Autoparts on thursday.
Author:  PhillipM [ Mon Jun 14, 2010 11:52 am ]
Now that's weird, because the moly is worse for the syncro's than any synthetic oil!
Personally I find CRX 75w90 NT works very well in most old EP90 specced gearboxes, never tried it in an 091, but it works well in the peugeot MA gearboxes and they're really fussy about oil.
Author:  RaceBugg1098 [ Mon Jun 14, 2010 12:09 pm ]
weird, yes! Its something an old racer told me, and it seems to work
Author:  bruce 1 [ Mon Jun 14, 2010 12:33 pm ]
tw9294 wrote:
Yeah why not?
Weddle says to do that way and, I would say they are right. And I would say racebug1098 hit the nail on the head.
Author:  PhillipM [ Mon Jun 14, 2010 1:08 pm ]
It's probably the tenaciousness of the grease helping them match speeds quicker, although you'd probably be better off with an oil that's a lot thinner when cold as that'll reduce the thickness of the boundary layer between the synchro cones. (If you can't find anything suitable, mix the gearbox oil 2 to 1 with Silkolene Pro RSF 2.5w - it's a damper oil but the makeup is inherently compatible with a gear oil, it's got a fantastic viscosity index - don't be tempted to use the Fox or King oils if you have it laying around, too thick and unstable :D )
Anyhow, not only is the moly in the grease not good for the synchro's, the complex soaps from a grease in the gearbox aren't good either as they tend to allow micro-caviation to occur on the meshing teeth which accelerates wear and tear.
Total BV spec 75w80 is also a good one for old synchro 'boxes, if you're looking for something cheap.
Author:  rockrockets1 [ Mon Jun 14, 2010 2:22 pm ]
I always used Royal Purple .I have only broke 091 when I knew it was about to happen [They can only take so much] But I never had a breakdown because of my oil . I also run full Synthetic in my Stump grinder gear boxes .Under extreme loads it will stay in longer not boil
Author:  RaceBugg1098 [ Mon Jun 14, 2010 3:49 pm ]
I run penzoil 85-95 mixed with Redline shock proof gear oil. Lets face it here, if any of my buggies break a transmission due to not having the correct oil before I break 'em, I'm going to be a happy camper :mrgreen:
Author:  PhillipM [ Mon Jun 14, 2010 5:05 pm ]
Hell, I could run it on dish soap and be OK :lol:
Author:  kybuggy1 [ Mon Jun 14, 2010 6:47 pm ]
Thats crazy. You run Weddle stuff?
Author:  RaceBugg1098 [ Tue Jun 15, 2010 8:07 am ]
yep! Well I havent broke one since 2007 race season, which was a bad case that led to a bad 1st and 2nd gear.
Author:  kybuggy1 [ Tue Jun 15, 2010 9:06 pm ]
WOW :shock: You say that like 3 yrs without a broke tranny is a good thing.
And you aint the only one I've heard that from. I dont understand how folks break Weddle stuffed 6 ribs so often. I know that racing is very tough on everything, but there is 20 yr old trannies in our group that have been absolutely punished with hi rpm Stage 4 clutch drops hooked to strong 2500s (or bigger) on fresh sharpened firestones in good biting dirt. They withstand this abuse for years n years every weekend. Must be something Chuck does when he builds them. :wink:
My tranny is about the only thing on my buggy I am NOT worried about breaking. 8)
Author:  Firebug [ Tue Jun 15, 2010 10:15 pm ]
Probably got a lot to do with weight and tire size too :|
Author:  RaceBugg1098 [ Wed Jun 16, 2010 8:02 am ]
i dont think it was even me being rough on it, the case was bad and should have been replaced when we built it. I dont get too worried about breaking it, lord knows im not too worried about it when I'm on the track :mrgreen: double clutchin it at 4000rpm and 60+mph jumps on the throttle arnt very easy on them either. all clear thoughts and common sense fly out the window net when your battleing for 1st place :mrgreen:
