| did vw put 3 ribs in vanagons?? http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=9584 |
| Author: | 1641buggy [ Sun May 30, 2010 10:34 pm ] |
| Post subject: | did vw put 3 ribs in vanagons?? |
i have a 3 rib that looks a little bit different then the one in my buggy.the guy i got from said that ut came out of a vanagon.. |
| Author: | Firebug [ Sun May 30, 2010 11:40 pm ] |
| Post subject: | Re: did vw put 3 ribs in vanagons?? |
3 ribs came in the VW Bus..the Vanagons had 6 ribs, so did some bus. Some folks call them all Bus or Vanagon,,including me sometimes. |
| Author: | Maddog [ Mon May 31, 2010 12:41 am ] |
The early vanagon diesels had a 3 rib main case. |
| Author: | 1641buggy [ Mon May 31, 2010 5:29 am ] |
can i send you a pic and you can tell me what its out off..??? it looks like a 3 rib but its a little different.will anything interchange with a normal 3 rib..?? |
| Author: | rail1914 [ Mon May 31, 2010 7:53 am ] |
the 68 3rib bus looks different to |
| Author: | RaceBugg1098 [ Mon May 31, 2010 8:16 am ] |
is it a nose shift or side shift? I just got rid of a vanagon 3 rib side shift. It had a 091 part # stamped everywhere on it, so it really was a 6 rib (at least on the inside). |
| Author: | 1641buggy [ Mon May 31, 2010 4:23 pm ] |
the # on the tranny is 002 301 103...does anybody know what its out of now..??? |
| Author: | ridenrace6 [ Mon May 31, 2010 11:31 pm ] |
1641buggy wrote: the # on the tranny is 002 301 103...does anybody know what its out of now..??? is tha the # on the bottom of the main case? |
| Author: | RaceBugg1098 [ Tue Jun 01, 2010 8:11 am ] |
002 is three rib, 091 is six rib. |
| Author: | 1641buggy [ Tue Jun 01, 2010 5:48 pm ] |
it's a side shift 3 rib.will it bolt up to a type1 motor and can you take the nose cone off an early style 3 rib and put it on a side shift 3 rib.so that it'll shift like and early 3 rib..?? what parts will interchange..??? |
| Author: | Maddog [ Tue Jun 01, 2010 6:25 pm ] |
Most likely it is a 5.86 ring&pinion, easily broken, not worth converting to front shift. |
| Author: | chris38375 [ Fri Jun 04, 2010 12:43 pm ] |
Maddog wrote: Most likely it is a 5.86 ring&pinion, easily broken, not worth converting to front shift. if its a 5;43 i want it |
| Author: | shadetree [ Wed Jun 16, 2010 7:47 pm ] |
I just got one of these 3 rib side shifts from a friend of mine. He swore it drove like a 6 rib, but the count of the teeth say different. 38-7 Not what I wanted. For Sale |
| Author: | Firebug [ Wed Jun 16, 2010 8:41 pm ] |
shadetree wrote: I just got one of these 3 rib side shifts from a friend of mine. He swore it drove like a 6 rib, but the count of the teeth say different. 38-7 Not what I wanted. For Sale chris38375 wrote: Maddog wrote: Most likely it is a 5.86 ring&pinion, easily broken, not worth converting to front shift. if its a 5;43 i want it there you go |
| Author: | chris38375 [ Wed Jun 16, 2010 10:34 pm ] |
how much????????????????????????????????????/ |
