PostPosted: Sun May 30, 2010 10:34 pm
i have a 3 rib that looks a little bit different then the one in my buggy.the guy i got from said that ut came out of a vanagon..
PostPosted: Sun May 30, 2010 11:40 pm
3 ribs came in the VW Bus..the Vanagons had 6 ribs, so did some bus. Some folks call them all Bus or Vanagon,,including me sometimes. :oops: good question :?
PostPosted: Mon May 31, 2010 12:41 am
The early vanagon diesels had a 3 rib main case.
PostPosted: Mon May 31, 2010 5:29 am
can i send you a pic and you can tell me what its out off..??? it looks like a 3 rib but its a little different.will anything interchange with a normal 3 rib..??
PostPosted: Mon May 31, 2010 7:53 am
the 68 3rib bus looks different to
PostPosted: Mon May 31, 2010 8:16 am
is it a nose shift or side shift? I just got rid of a vanagon 3 rib side shift. It had a 091 part # stamped everywhere on it, so it really was a 6 rib (at least on the inside).
PostPosted: Mon May 31, 2010 4:23 pm
the # on the tranny is 002 301 103...does anybody know what its out of now..???
PostPosted: Mon May 31, 2010 11:31 pm
is tha the # on the bottom of the main case?
PostPosted: Tue Jun 01, 2010 8:11 am
002 is three rib, 091 is six rib.
PostPosted: Tue Jun 01, 2010 5:48 pm
it's a side shift 3 rib.will it bolt up to a type1 motor and can you take the nose cone off an early style 3 rib and put it on a side shift 3 rib.so that it'll shift like and early 3 rib..?? what parts will interchange..???
PostPosted: Tue Jun 01, 2010 6:25 pm
Most likely it is a 5.86 ring&pinion, easily broken, not worth converting to front shift.
PostPosted: Fri Jun 04, 2010 12:43 pm
if its a 5;43 i want it
PostPosted: Wed Jun 16, 2010 7:47 pm
I just got one of these 3 rib side shifts from a friend of mine. He swore it drove like a 6 rib, but the count of the teeth say different. 38-7 Not what I wanted. For Sale
Aircooled power!
PostPosted: Wed Jun 16, 2010 8:41 pm
there you go :wink:
PostPosted: Wed Jun 16, 2010 10:34 pm
how much????????????????????????????????????/
