| 3 rib parts interchange? http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=9576 |
| Author: | ridenrace6 [ Fri May 28, 2010 2:47 am ] |
| Post subject: | 3 rib parts interchange? |
i was wondering if any parts in the 68 model 3 rib (acorn nuts behind drive flanges) will interchange with the newer 3 ribs (screw in adjusters behind drive flanges) ? the reason im asking is i have a 68 3 rib with a busted ring and pinion and i have 2 newer 3 ribs and one has a busted 1st gear and the other has busted spider gears and i was wandering if i could use the 68 3 rib to fix the other 2 ? |
| Author: | chris38375 [ Fri May 28, 2010 10:18 am ] |
| Post subject: | Re: 3 rib parts interchange? |
it will work,now fix it |
