It is currently Mon May 04, 2026 12:51 am
 Post subject: inner pivot bushings
PostPosted: Mon Feb 18, 2008 9:22 pm
OK ,, showing my ignorance... on the inner pivot bushings on the rear trailing arms there are 2 large washers,,, Where do they go? :?
PostPosted: Mon Feb 18, 2008 9:25 pm
on the outside
PostPosted: Mon Feb 18, 2008 9:29 pm
that explains some things
:oops:
PostPosted: Wed Feb 20, 2008 11:25 am
I thought that was a matter of adjustment?
From what I've read, you put them in different spots to adjust your camber (?) or something like that. Depending on your arms, lift, etc.
Or...I could be completely wrong. :?
Get me that hammer, pronto!
PostPosted: Wed Feb 20, 2008 11:32 am
One on each side of the bushing.
Like this.............-ll--ll-.........the straight up-and-down lines on the outside is the stock bracket, and the inside lines is the washers, the 2 dotted lines in between is the bushing, and the 2 outside dotted lines is the bolt.
The setup you see above will give you "zero" setting, put your trailing arms on the buggy and bolt them up on your spring plate and see if the arms are pushing the plates too far inwards or outwards. If the arms are pushing the plate too far outwards, take them back off and take the washer on the "inside" end off and put it back on like this...-lll--l-...(+1 setting) and this should take care of it, if it's too far inwards, do it like this...-l--lll-...(-1 setting) and that should take care of it. These that I'm showing you on here is the driver's side, then do the opposite on the passenger side.
If you have a good set of trailing arms, you should be able to use the "zero" setting with no problems. Hope this helps
PostPosted: Wed Feb 20, 2008 3:56 pm
thanks,,,for the best alignment I put a washer on each side. Looks good now. thanks again. :wink:
the 2 go beside each other if ur arms where built right u dont need to adjust them they both go on the outside together
PostPosted: Wed Feb 20, 2008 4:04 pm
has anyone ever looked at a stock bug? -II---- thats the way it goes not 4 washers jus 2
PostPosted: Wed Feb 20, 2008 5:05 pm
Not to argue, but I've tore down plenty of stock beetles, as I'm sure many folks on here have. All the arms on the last two had one washer on each side. Never paid attention to most of them. My buddy's Superbeetle thats sittin in my shop has one washer on each side on drivers side, and two outside on the passenger side. The passenger side of the car was previously wrecked and (half-assed) repaired by a past owner.
Could be coincidence, probably not.
I put one on each side of the arms on every buggy I have and it seems to work fine. Guess it doesnt really matter much in the woods.
PostPosted: Wed Feb 20, 2008 5:22 pm
[quote='kybuggy1']Not to argue, but I've tore down plenty of stock beetles, as I'm sure many folks on here have. All the arms on the last two had one washer on each side. Never paid attention to most of them. My buddy's Superbeetle thats sittin in my shop has one washer on each side on drivers side, and two outside on the passenger side. The passenger side of the car was previously wrecked and (half-assed) repaired by a past owner.
I put one on each
PostPosted: Wed Feb 20, 2008 6:28 pm
they go on the outside for sure
PostPosted: Wed Feb 20, 2008 6:30 pm
I know that one of my VW shop manuals states that both washers go on the outside. Some of them don't mention this though. I can't remember which one says that.
PostPosted: Wed Feb 20, 2008 8:54 pm
Every bug I have ever worked on has had them both on the outside. There are two of them so you can have adjustment if necessary.
PostPosted: Wed Feb 20, 2008 9:58 pm
OK OK I stand corrected!
Had to check my manul...My ex-boss!
He said they both BELONG on the outside, but he's seen them everywhere. And that they can be moved to correct alignment, just like BadVW said.
Maybe it was coincidence. :roll:
PostPosted: Thu Feb 21, 2008 7:54 pm
My 3x11 trailing arms have one washer inside and 1 inside. This made the alignment with the dual spring plates better and it works just fine.
PostPosted: Thu Feb 21, 2008 9:12 pm
3x11? have picks
PostPosted: Fri Feb 22, 2008 8:31 am
[quote='kybuggy1']OK OK I stand corrected!
Larry[/quote]
I did not use any :lol: :lol:
PostPosted: Fri Feb 22, 2008 8:38 am
Maybe that's why some say you have a screw loose :lol:
PostPosted: Fri Feb 22, 2008 1:15 pm
they say that 'cause he's from GA. :twisted: :lol:
PostPosted: Fri Feb 22, 2008 6:23 pm
[quote='purplerail']3x11? have picks[/quote]
X2
Shine is fine, but flats where its at
PostPosted: Fri Feb 22, 2008 9:33 pm
No pictures purple rail, Firebug has seen them though. The axles are 26"s long. The wheels are totaly inverted. Like a corvete wheel. So that the buggy is regular width.
