BAD NOISE
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=9382
Author:  tw9294 [ Wed Apr 28, 2010 7:13 pm ]
Post subject:  BAD NOISE
Got to drive my buggy through all 4 gears for the first time since new eng/trans combo. Trans make VERY LOUD whining noise in 3rd and 4th gears under load. :evil: :evil: I'm assuming i have a bearing concern and i'm thinking 3rd and 4th share a shaft maybe? This is vanagon 6rib. Any help is greatly apreciated.
Author:  Roy [ Wed May 05, 2010 11:54 am ]
Post subject:  Re: BAD NOISE
Yes, 3rd and 4th share a shaft and yes it would be a bearing. Tear down time. Do it now before it gets expensive. :roll:
Author:  turboblue [ Wed May 05, 2010 1:01 pm ]
If you don't want to fool with it, send it back in that blue crate.
We'll see what's up with it and give you a $ number.
Author:  MickeyMouse [ Wed May 05, 2010 9:03 pm ]
Mine was doing the same thing. I was hoping I could wait until next year to rebuild but I did not make it. My tranny gave up at D&K. I wonder how much damage I did when I blew up my tranny..
Author:  tw9294 [ Wed May 05, 2010 9:31 pm ]
I got another trans. thanks tb. I think i'll use the noisy one to learn and build. Super diff and maybe different gearing after i see how i like stock gearing. I'd like to learn the ins and outs of these myself. I have access to many tools and i'm capable just need a manual(any sugestions apreciated) and a list of things that should be absolutely upgraded while in there. Thanks everyone. Tony
Author:  passat2800 [ Wed May 05, 2010 10:39 pm ]
In the past when I had 3rd or 4th hard to deal with, the pinion bearing was going out ,subsequently the r&p went out.The shafts share bearings and if they are mis aligned THE TEETH ARE MIS ALIGNED and you have trouble.You are very right about your bearings.
Author:  Maddog [ Wed May 05, 2010 11:00 pm ]
I usually add a wide flange pinion nut,hand pack 1st, and install thrust plate if all else is good.
