 Post subject: BELLHOUSINGS
PostPosted: Sat Feb 27, 2010 11:59 pm
What are the differences between a pre 83 091bellhousing and a 83-91 091 sideshift bellhousing? Are there any and are they interchangable. Same length? Thanks.
 Post subject: Re: BELLHOUSINGS
PostPosted: Sun Feb 28, 2010 12:24 am
all the 6 rib bells r the same except for the ones with a hydraulic clutch from the factory and then the clutch throw out arm is the only differnce from what i have seen that is i run a 84 up bell with the factory slave cylinder and a neal master
PostPosted: Sun Feb 28, 2010 12:25 am
the cross shaft is differrent,,but that is not what you asked is it?
PostPosted: Sun Feb 28, 2010 10:47 am
whats the diference in cross shafts? I got a side shift vanagon trans but is has wrong bell housing. Its small has a very small cross shaft and no throwout bearing guide. I already have a kep adapter kit and i don,t want to get a bellhousing if it won,t work. Will a 3 rib bell work? I will buy or trade for a bellhousing. Thanks again.
PostPosted: Sun Feb 28, 2010 11:21 am
I think the cross shaft is splined wrong , and so the arm is pointed in a different direction.
PostPosted: Mon Mar 01, 2010 1:09 pm
So will any bell work as long as i have correct starter and clutch assembly for the bell? This is an early bellhousing correct? Thanks again. ImageImageImage
PostPosted: Mon Mar 01, 2010 7:33 pm
That is an early 3 rib bellhousing.
Your linkage shipped today from the machine shop.
Thanks Tony
