It is currently Mon May 04, 2026 12:05 pm
 Post subject: 83 vanagon transmissionn
PostPosted: Thu Feb 25, 2010 7:14 pm
I found a 1983 vanagon, It is manual shift. I looked under it, an it looks like a 6 rib. Does anyone know for sure?
Woody
PostPosted: Sat Feb 27, 2010 9:58 pm
PostPosted: Sun Feb 28, 2010 12:00 am
its is a 6 rib . you need to see where the shifter is on the trans . i beleive its this one its the least disired of the sideshifts.
PostPosted: Sun Feb 28, 2010 3:13 pm
starter is on top of the bell housing
PostPosted: Sun Feb 28, 2010 3:52 pm
sounds like a diesel trans
PostPosted: Sun Feb 28, 2010 8:50 pm
sounds like one to me! is this it?
PostPosted: Sun Feb 28, 2010 10:55 pm
similiar, but does have 6 ribs. The bell housings are the same.
PostPosted: Mon Mar 01, 2010 7:40 pm
Engine still in it?
Air or water cooled?
Early 83 was air, late was water IIRC.
Big difference in trannies.
Both have the 6 rib "look".
PostPosted: Mon Mar 01, 2010 9:43 pm
diesel engine in it
PostPosted: Sat Jul 31, 2010 1:11 am
turboblue wrote:
Engine still in it?
I pulled a 6 rib sideshift from a 03/1983 vanagon and it was watercooled
Awesome 2387 Beeline Cobra
PostPosted: Sat Jul 31, 2010 9:01 am
That 6 rib NOSE side shift is a 457 2 spyder diff, and the 3 rib is a 542 2 spyder. Both pictured are from 80- early 83. Your trans code is located on the bottom corner on the driver's side. They are such codes as ab, abd, dk, acw etc. Go to a british site WWW.partsemporium.co.uk. Then look under type 25 gearbox codes.(vanagon).Then get rid off it and get a front wheel drive motor and trans ran longways to a ford continental irs diff.Preferably a v6 sitting in the back of a 4 seater frame.The Pull a Parts are full of $75 nissan toyota etc transmissions.Oh yeah, Columbus said the world is round.For an expensive idea, go to woodsbuggy forum then under TRANSMISSIONS go to mystery machine.Dave out.
PostPosted: Mon Aug 02, 2010 12:33 pm
Graden2387 wrote:
turboblue wrote:
Engine still in it?
That is considered late.
Model year starts the previous year in August.
Your March vanagon was 7 months into the 83 model year.
