axle??
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=8697
Page 1 of 2
Author:  hauser2169 [ Wed Feb 10, 2010 8:44 pm ]
Post subject:  axle??
k so im gettin pretty close to havin a rollin buggy. i need axles. the ones that came on it are for a sedan tranny.i now have a 3 rib tranny. what are my options, just gettin cv's or just new axles. i want to do it right the first tiem. i need to know what to get, size, and whatever else i would need lol.
Author:  dunebuggynut [ Wed Feb 10, 2010 8:56 pm ]
Post subject:  Re: axle??
All buggy shops should stock the long spline axles you need. They are called bus to sedan axles. Also get type 2 stub conversions if you didnt already. I blew 12 car CV's in 3 rides. Youll thank me later.
Author:  dunebuggynut [ Wed Feb 10, 2010 8:59 pm ]
Thats if you are running stock boxed arms only BTW.
Author:  buggiejunky [ Wed Feb 10, 2010 9:16 pm ]
if ur running stock arms i have the axles u need theres 3 of them 100 shipped there listed on here under 15 5/8 axle in parts for sale there swayaway
Author:  hauser2169 [ Wed Feb 10, 2010 9:22 pm ]
i think im running stock arms, pretty new to this so i dont know as much as i like... and buggy junky, il prob grab them from you, just want to make sure thats what i need. i added the pic of my arms to see if they wre stock..
Author:  bmoore [ Wed Feb 10, 2010 9:24 pm ]
i dont see the pic
Author:  tw9294 [ Wed Feb 10, 2010 9:51 pm ]
I,ve got the stub axles you need to use bus cvs at your control arms. They are listed in parts for sale. Got cvs and boots too.
Author:  hauser2169 [ Wed Feb 10, 2010 11:33 pm ]
what all do i need for the axles. waht are stubs?> i know i need cv's.. buggy junky do you have pics, and do yours come with cv's
Author:  dunebuggynut [ Wed Feb 10, 2010 11:43 pm ]
The stub axles go in the trailing arms & the outer CV's bolt to em. Simple thing to swap out.
Author:  buggiejunky [ Thu Feb 11, 2010 12:26 am ]
i have pics of axles just pm me ur email and ill send them they do not have any cvs
Author:  hauser2169 [ Thu Feb 11, 2010 9:58 am ]
So I could use the existing stubs from my existing axles
Author:  dunebuggynut [ Thu Feb 11, 2010 10:30 am ]
A (stub axle) is all one part. Its a solid piece that connects the CV joint to the drive splines in the rotors. If you know somebody with the machines they can grind or turn the lip down & redrill the bus CV pattern on em. Thing stubs work but are tuff to find. Buggyjunkies are already redrilled for bus if you dont know a machinist.
Author:  hauser2169 [ Thu Feb 11, 2010 5:41 pm ]
So if I bought the stubs, cv's and axles, that's all I'll need?
Author:  dunebuggynut [ Thu Feb 11, 2010 5:48 pm ]
Dont forget bus boots but yep, thats it. Use your bearings & CV bolts. You will need a nut whacker to swap em too. 8 bucks
Author:  nitro_mudder [ Thu Feb 11, 2010 7:56 pm ]
Not a hi-jack, what is a nut whacker? Is that like a hammer wrench?
Author:  dunebuggynut [ Thu Feb 11, 2010 8:05 pm ]
http://www.appletreeauto.com/hd-36mm-rear-axle-nut-tool-c-4-p-2-pr-835.html
NUT WHACKER
When you need to get a nut off beat it with this..... :twisted:
Author:  Maddog [ Thu Feb 11, 2010 8:09 pm ]
NUT WHACKER
Hey, I know her.
Author:  bmoore [ Thu Feb 11, 2010 8:10 pm ]
NUT WHACKER
i was wondering what that was also. nut whacker :mrgreen:
Author:  dunebuggynut [ Thu Feb 11, 2010 8:13 pm ]
You missed my edit......Boy I could really get going on this one. :mrgreen: :mrgreen: :mrgreen:
Author:  nitro_mudder [ Thu Feb 11, 2010 8:35 pm ]
Hmmmmm, I always just used a socket and a 3/4 impact
Author:  dunebuggynut [ Thu Feb 11, 2010 8:39 pm ]
ImageNut Whacker
If this pushes it Ill remove it.
Author:  dunebuggynut [ Thu Feb 11, 2010 8:44 pm ]
This is old school. I smack it with a sledge to tighten em up. Even my 3/4 drive cant equal this puppy.
Author:  nitro_mudder [ Fri Feb 12, 2010 1:26 am ]
ya we use those on big pipe flange bolts, like 20" and up pipe.
Author:  tw9294 [ Fri Feb 12, 2010 11:27 pm ]
Stub axles drilled for bus or bug cvs and stock bus cvs with boots and allen head bolts. These are stock bus axles and too long for your stock arms but you can toss thim in the corner.ImageImage
Author:  bmoore [ Fri Feb 12, 2010 11:46 pm ]
sorry about the highjacking but couldnt find this ad for these axles. how much for the bus to bus cv's and axles?
