Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: 3.44 first gear
PostPosted: Thu Jan 28, 2010 5:02 pm
Has anybody ran a 3.44 first gear in there trans in the Woods?
 Post subject: Re: 3.44 first gear
PostPosted: Thu Jan 28, 2010 11:31 pm
Yea thats what i run.alot of people around here run 3.44 1st and 2.36 2nd with stock 4.56 ring gear.i have to take off in 1st and then hit 2nd. well now with my new 2387 i can take off in 2nd as long as its pretty smooth at the bottom.i know a few of the guys are getting ready to switch to 3.10 1st and 2.46 2nd.
PostPosted: Fri Jan 29, 2010 12:23 am
What is the stock set? I have 4.57 rp, just curious
PostPosted: Fri Jan 29, 2010 2:23 am
Steve I'm going to a 355 and 223 only because I got them CHEEEEEEEEP at Lansing,I think they would suite me better for trail riding than the stock gearing and anything will help me climb lol ,I had them magged and cyroded (frooze) but I'm still thinking about a ring&pinion and it will def get closer 3&4
Steve Did you get your new diff yet? How much does it weigh??
Nitro stock 378 and 206 I think
PostPosted: Fri Jan 29, 2010 9:51 am
Typical stock 6 rib ratios are 1/2 - 3.78/2.06 M/S 3 - 1.26 and 4 - .86
What diameter tires are you running? Mine are 33" (actual 32") Does it lug at slow speeds?
PostPosted: Fri Jan 29, 2010 9:54 am
Who makes a 355/223? I was wanting something in the 355 range. Nothing on the diff yet.
PostPosted: Fri Jan 29, 2010 11:08 am
So you guys are wanting a higher then stock 1st and 2nd?
PostPosted: Fri Jan 29, 2010 11:20 am
I find that stock 1st gear winds out to quickly and 2nd needs more wheel speed to work. Hense I need closer ratios.
PostPosted: Fri Jan 29, 2010 12:57 pm
Ok, just seems that alot of guys want that lower ger they get in 3 and 5 ribs. I like the high gear myself.
PostPosted: Fri Jan 29, 2010 1:02 pm
All depends on power to weight ratio. Less HP benifits from 3 or a 5 rib ratios. large HP motors work better on the 6 rib ratios. I have a few ponys in my motor and I can use the higher gears.
PostPosted: Fri Jan 29, 2010 1:23 pm
What ring gear are you runnin Ody? The reason I ask is I am tryin to decide whether to go with the 3.11/2.17 or the 3.44/2.36. I am runnin the 4.83 ring gear. Right now my first is way to low and second is just a little to high. I wish they made a 3.11/2.36 for the midshift. I think I will be able to climb in second with the 2.36. I just wish I knew for sure. That is alot of money to gamble with.
PostPosted: Fri Jan 29, 2010 1:45 pm
I have the 3.11/2.36 and run a 4.86 r/p and I run in second gear but remember I also have 1.5/1 reduction in my babychains. I dont think it would work without the chains reduction , even with the 230 hp. I think you would still have a first gear tranny.
PostPosted: Fri Jan 29, 2010 1:47 pm
Terry, I believe your running the same trans I am with the 4.83 R&P I am runninmg 32" dia Boggers. What tires are you running? I am experiencing the same senario as you. I would not go 3.11 at all if your into tight woods running. A 3.44 would be the minimum. I am deciding between the 3.44/2.36 and the 3.75/2.36. I would like to have a 2.46 second however its not offered for the Midshift .
PostPosted: Fri Jan 29, 2010 3:51 pm
Ody, you will like the 3.44 first and 2.36 second gears that's what I have now but my second is 2.46. You can lug around just fine I mostly lug around in 2nd gear and I have a 2276cc and you got a turbo-charged suby engine I mostly use first just to climb hills and to lug slowly up some hills. You will not regret using this gearset even though you got a midshifter with a lower ring and pinion and taller tires than mine, it will pretty much be the same as mine.
PostPosted: Fri Jan 29, 2010 3:57 pm
Terry, I think you will like the 3.44 and 2.36 gearset better because the type riding that you want to do. You know what I'm going to have. :twisted:
PostPosted: Fri Jan 29, 2010 6:33 pm
Right now I am running firestone v treads which are actually 28"tall. I have the power and torque to climb in second I just cannot get it to spin on command at lower rpm's in 2nd. It just hooks and goes. Which leads to me hitting a tree or something. I want to be able to spin the tires on command. I don't know I have been racking my brain on this for the past two days, it is driving me absolutely insane. Ody after watching these guy's with the 3.44 I think it will be fine even if it is tight woods.
Firebug with you running the 1.5 to 1 reduction that should make your r/p 7.29 I think, and you are running 35" tires. If I am right your 2nd gear at 7000 rpm is 42 mph. Here is the equation I used rpm x tire /gear ratio / ring gear / 336 = mph
Mine with the 2.36 2nd and 4.83 at 7000 rpm will be 51 mph. And at 6000 rpm I will be at 44 mph. I am making pretty good power and tq between 4500 rpm and 6000 rpm. And the 3.11 at 7000 rpm on mine will be 38 mph. Which I don't think is fast enough. Someone please help me decide. (ky boys)
PostPosted: Fri Jan 29, 2010 6:47 pm
I am having to learn how to drive. My buggy is too heavy to spin on command so I am trying to climb with traction. My gear ratios may not work for a lighter buggy. :?
PostPosted: Fri Jan 29, 2010 6:54 pm
Yeah, I know what you mean firebug. I really need to learn how to drive. I would like to hear the secret ky gearing. If I can hit a long hill after having my motor spun up to 3500 in 2nd I can get it to spin by playing with the throttle in second right now. But I just don't know if 2.36 will be enough for short hills,I wish I could get a 2.90 first. I think that would be perfect for hill climbing. Or a 2.90 second
PostPosted: Fri Jan 29, 2010 11:38 pm
Ody my buggy loggs around good. im running 31" v treds but i like my 1st gear better when i ran 33 boggers. the area i run in most like v treds better. i still have boggers to for when its wet. And for you terry i think you will be just fine after you learv to drive. YOU CANT DRIVE 8) 8) 8) :lol: :lol:
PostPosted: Sat Jan 30, 2010 9:10 am
Gear ratios are just like cams. It depends on you buggy, will your motor pull it?? is you buggy heavy?? what kind of driving do you do?? A good trany builder takes all this into consideration if you ask them what gears do I need?
And remember some gear ratios are not very strong. (the teeth are thin) So when you pick these kind, if you hammer on them often you could break them easy.
PostPosted: Mon Feb 01, 2010 4:47 pm
How much does your Buggy weigh? Mines at 2500#
PostPosted: Mon Feb 01, 2010 4:51 pm
Odyknuck wrote:
Mines at 2500#
:shock: :oops: Woah.
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Mon Feb 01, 2010 6:07 pm
Its ok Koko, it still moves plenty fast. Its more like the buggies in the Baja 1000 then a KY hillclimber. Hopefully you and pops can show up to wellsville this year and see some of these heavy buggies.
PostPosted: Mon Feb 01, 2010 6:38 pm
I'll take your word for it! Yea, maybe we will. Or y'all come come to D&K? :D We may make it up there this year.
-Dakotah/koko
-Dakotah/koko
