Grinds but changes with motor off
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=8212
Author:  passat2800 [ Fri Dec 04, 2009 3:27 am ]
Post subject:  Grinds but changes with motor off
If you push the clutch and the gears grind and won't go in gear it is because the flywheel has rusted to the clutch.Probably been sitting too long in the rain? Crank motor while in 1st with one rear wheel floor jacked. At idle, have someone release floor jack and when the spinning wheel hits the ground the clutch and flywheel will break loose.Same with too much grease getting hot and oozing out of gland nut and glueing pressure plate to flywheel.If only 4th gear changes (becuase it is nearly 1:1) , you will know this is your problem.Hey, I read it in a vw book once, but it said to remove the motor. :o
Author:  davehix [ Fri Dec 04, 2009 5:42 pm ]
Post subject:  Re: Grinds but changes with motor off
:shock: :shock: :?: :?: :?: :? :? :? :mrgreen: :mrgreen: :lol:
Author:  chris38375 [ Fri Dec 04, 2009 6:14 pm ]
im really freakin confused
Author:  rockrockets1 [ Sat Dec 05, 2009 12:21 am ]
I am at a loss for words :shock:
Author:  tw9294 [ Sat Dec 05, 2009 12:38 am ]
Rain,grease,glue. Say what?
Author:  giveitagallon [ Sat Dec 05, 2009 12:53 am ]
:oops: ill have what he is smokin ! to go please ! :oops: then we can talk about fixin your problem :lol:
Author:  chris38375 [ Sat Dec 05, 2009 2:28 am ]
i am smokin what hes smokin and im still confused
Author:  davehix [ Sat Dec 05, 2009 2:36 am ]
And i thought it was only me :roll: :mrgreen:
Author:  ridenrace6 [ Sat Dec 05, 2009 2:50 am ]
i thought i must have missed something when i read this right after he posted it but i guess im not alone he must have been awfully deep in the "scooby snacks"
Author:  Maddog [ Sat Dec 05, 2009 3:06 am ]
Sounds like my old tractor, if it has been settin too long, I have to crank it in gear and ride it around with the clutch pushed in while stomping the brakes trying to get the clutch to release [break free=disk rusted to flywheel].
passat2800 wrote:
Been sitting to long in rain? Crank motor while in 1st with one rear wheel floor jacked. At idle release floor jack and clutch and flywheel will break loose.Same with too much grease getting hot and oozing out of gland nut and glueing pressure plate to flywheel.
Author:  Rick [ Sat Dec 05, 2009 9:41 am ]
i guess I've been doing myself a miss service by not greasing my gland nut, where is that zerk :?: :roll:
