| 5 or 6 rib with a 2276 http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=8210 |
| Author: | vw_brandon [ Thu Dec 03, 2009 11:44 pm ] |
| Post subject: | 5 or 6 rib with a 2276 |
which one?? |
| Author: | hillaholic [ Thu Dec 03, 2009 11:48 pm ] |
| Post subject: | Re: 5 or 6 rib with a 2276 |
I vote a 6 rib for more wheel speed and strength. |
| Author: | Roy [ Sat Dec 12, 2009 9:10 am ] |
It depends on what you are trying to do. Both are good transmissions. In STOCK form, the 6 rib is stronger. |
| Author: | moondog [ Sun Dec 13, 2009 11:43 pm ] |
imo cant go wrong with the 6 rib as long as ur motor will hump it |
| Author: | vw_brandon [ Mon Dec 14, 2009 6:37 pm ] |
Roy wrote: It depends on what you are trying to do. Both are good transmissions. In STOCK form, the 6 rib is stronger. just wantin to know which one will hold up to a 2276 best im guessin ill go with the 6 when i get the motor |
| Author: | kyjr.buggy1 [ Tue Dec 15, 2009 10:07 pm ] |
Yea, in stock form, any 6 rib will hold up better than a 5 rib on any motor. Like Roy says, buy the best and cry once. -Dakotah/koko |
