It is currently Mon May 04, 2026 1:54 am
 Post subject: 6 rib gearing
PostPosted: Mon Aug 24, 2009 8:21 pm
Hi Guys
New guy here.
I am in the process of building a 4 seat Beeline Pack Rat.
Bus 2.0 and 6 rib tranny for riding in the North Georgia mountains and woods.
I was wondering if the 1st and 2nd gears could be changed to make 2nd low like 1st and 1st a granny gear for creeping in the rough? Or would I have to change all four?
Tim
 Post subject: Re: 6 rib gearing
PostPosted: Mon Aug 24, 2009 10:55 pm
u can change jus 1st and 2nd,cost about 800 to do it,if u do it urself,i really dont know what labor is on a tranny now
PostPosted: Mon Aug 24, 2009 11:11 pm
I got my second down to what my first was by using aftermarket first and second gear set with a 4.86 ring/pinion with 1.5-1 gear reduction in my babychains,,,,it takes a lot to make second as low as first. You can do it but it aint easy. If you dont use chains you would have to go as low as you can with the R/P plus weddle gear set but the lower you to with the R/P the weaker it gets. If you have a lot of power and a light buggy and run 31" tires, you can use a second that is lower than stock but still not as low as your first.
PostPosted: Thu Oct 22, 2009 6:04 pm
If you are trying to do it on a budget, just change out the ring and pinion to a 5.37 out of a diesel Vanagon. This will lower everything all the way across the entire spectrum.
PostPosted: Mon Nov 09, 2009 12:41 am
Could some one post a link to a stock gearing chart. I'd like to know what I've got before considering any changes. Thanks.
PostPosted: Mon Nov 09, 2009 9:01 am
I've got a better chart saved at home,,,but here is a good one too
http://www.ratwell.com/technical/Transa ... #diffvideo
http://74.125.113.132/search?q=cache:o0 ... clnk&gl=us
PostPosted: Mon Nov 09, 2009 6:37 pm
I run 4.38-2.46-1.72-1.18 4.57ring &33.14 boggers good trail riding tran .But not to good for hills 1st is to low & 2 is to hi .My son loves it . his been drive it sins he was 8 . Drews buit it after i broke 2 5.42 rp.
