 Post subject: Super Diff.
PostPosted: Tue Oct 20, 2009 2:16 pm
Can a super diff be installed while the trans is in the buggy with motor mounted?
MoblMec
 Post subject: Re: Super Diff.
PostPosted: Tue Oct 20, 2009 2:50 pm
No, You need to pull the bellhousing off to pull the diff out.
PostPosted: Tue Oct 20, 2009 2:54 pm
no way with the motor on and the axlles have to be took loose at the tranny and bell housing off if it is a bus tranny so you might as well pull it on out and do it on the table so the it will be much easier than in the buggy... not sure about if it can be done with a car tranny or not...
PostPosted: Tue Oct 20, 2009 8:31 pm
Motor removed,Axles removed,bellhousing removed, side plates or bells removed, diff removed,ring installed onto new diff then everything reinstalled.
