 Post subject: shift lever
PostPosted: Thu Oct 08, 2009 7:17 am
I had no reverse in this new buggy project I have gotten. Took the the front cover off to find the pin that the shift rod uses to move the interal lever had fell down. Looking at a blow up it appears to have had a clip on it. Does the small end go up or down? I see no grove for the clip. Could the piece that hold the clip in broken off? thanks
 Post subject: Re: shift lever
PostPosted: Thu Oct 08, 2009 9:49 am
The front cover holds that pin in place, when it is installed.
PostPosted: Thu Oct 08, 2009 6:43 pm
thanks, so when the cover is installed it rides on a portion of the cover to hold the pin in place with out a clip or such to support it. thanks again I'll go try it again.
PostPosted: Thu Oct 08, 2009 7:38 pm
thats it no clip,i think the small end goes up,it will only go one way
PostPosted: Thu Oct 08, 2009 11:01 pm
not sure but this might help
