It is currently Mon May 04, 2026 6:38 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
PostPosted: Sun Oct 04, 2009 6:51 pm
What is a super diff?
What is the advantage?
I have a 6rib out of a 79 bus. Not installed yet.
MoblMec
PostPosted: Sun Oct 04, 2009 8:28 pm
Superdiff has 4 spider gears insted of 2. Alot stronger
PostPosted: Sun Oct 04, 2009 8:32 pm
:lol:
PostPosted: Mon Oct 05, 2009 11:07 am
Do you all think a super diff is needed for a trail cruiser and mild off roader?
MoblMec
PostPosted: Mon Oct 05, 2009 11:40 am
MoblMec
I think a trail cruiser is gonna eventually wish he had a super diff,,,,eventually :wink:
PostPosted: Mon Oct 05, 2009 12:01 pm
I agree, unless you are talkin about gravel roads. You might get in a spot or two that you have to crack on it to get out of 'em. Never know what can happen even trail riding.
PostPosted: Mon Oct 05, 2009 12:56 pm
The more power you have the more stress on the Trans. The heavyer the Buggy the more stress on the Trans. The larger the tires the more stress on the Trans. The harder the trail the more stress on the Trans. The deeper the Mud the more stress on the Trans. The steeper the hill the more stress on the Trans. If you experience any one of these Items then get a Super diff. Look at it as cheap Insurance.
PostPosted: Tue Oct 06, 2009 10:25 am
Ok thanks for the info.
Now whats a new super dif and gears going to cost?
And is a used one worth the effort?
Moblmec
PostPosted: Tue Oct 06, 2009 11:26 am
You reuse your ring and pinion gears on the Super diff. I went with a used German super diff in mine. It was around 200 Bucks.
PostPosted: Tue Oct 06, 2009 11:51 am
That kind of money I could handel. Are they hard to install? I have installed spider gears and lock rite lockers on a jeep befor but when it came to setting up ring & pinnon and blue printing for backlash I used a pro to set it up.
Where would you look for a used super diff?
MoblMec
PostPosted: Tue Oct 06, 2009 12:54 pm
Because you have allready delt with the Jeeps you should not have any problem doing it. I set the backlash to .003" with a dial Indicator. It does require a special tool to get the bearing retainer rings off. You can make or buy one.
PostPosted: Tue Oct 06, 2009 1:04 pm
where can I get one for that? I need one for my wifes buggy.
PostPosted: Tue Oct 06, 2009 6:01 pm
Bruce, loan me some money. I want a dozen of 'em at that price :lol:
Seriously, you got a Helluva deal Ody. Last one I bought was $345 used from Weddle. For right now they are not available.
PostPosted: Wed Oct 07, 2009 2:43 pm
i was about to say 200.00 :shock: i payed 400 a pc for 2 of em cpl months ago...
PostPosted: Tue Oct 13, 2009 10:00 pm
I just bought 6, should have them in a week.
I'll be selling them for $350 ea, genuine vw 091 4 spider diffs complete.
PostPosted: Wed Oct 14, 2009 6:43 pm
I think Maddog has the deal .....I like the German OEM VW ones
PostPosted: Mon Oct 19, 2009 5:41 pm
$350 ea, genuine vw 091 4 spider diffs complete. see if you got them in a buddy needs one
PostPosted: Mon Oct 19, 2009 8:17 pm
Should have them by thursday.
Bill
PostPosted: Thu Oct 22, 2009 7:02 pm
They are here.
3 are sold, 3 are available.
PostPosted: Fri Oct 23, 2009 12:55 am
are the factory german diffs better than the weddle ones with a chromoly "hat"
PostPosted: Sun Oct 25, 2009 9:42 pm
Bought one of MadDog's German Super Diff's last night and His helper installed it for $30 .
Good deal, good looking diff.
Thanks Travis & Bill
MoblMec
PostPosted: Sun Oct 25, 2009 10:29 pm
You're mighty welcome.
Bill
PS...post a pic of that frame
PostPosted: Sun Oct 25, 2009 11:23 pm
I did n't realize that there were OEM German super diffs. Are they only aftermarket or were they used in production? I've seen Chinese ones advertised in Hot VW's for around $200 with out spider gears. The 9 tooth spiders never seem to be listed in the advertising. Would they be special order from some one like Weddel? I plan on getting one, but hav'nt finnish building my buggy yet. I want to run it for a while first, so I can decide wether or not to change gearing at the same time. Thank's Dave W.
PostPosted: Mon Oct 26, 2009 9:43 am
Yes, some late vanagons came with 4spider diffs .Don't think much of the chinese ones, only one I had experience with needed remachining before installation.
Weedle has them sometimes.
PostPosted: Fri Oct 30, 2009 1:08 am
You say some late model Vanagons. Can you narrow that down some. Right now I plan to use a 5 rib, I've had the nose cone machined so that I can use a bearing retaining plate, installed new output shaft seal and added heavy duty cross shaft. I do have a 6 rib side shift. But when I found it there was no bell housing and it seemed that some one had tried to remove the carier housing but had damaged the main bearing race. It might be junk( a trans jig) or it may be rebuildable, don't know.
If I could find one, would you recomend converting to nose cone style shifting, or would you recomend a cable shifter? If so, what style or brand? Thank's, Dave W.
