 Post subject: Sprocket bolts
PostPosted: Wed Sep 09, 2009 5:43 pm
Learned the hard way that the original size 8mm bolts shear so I upgraded to 7/16-20 socket head bolts,,here is a handy way to hold the stub axle in my craftsman drill press,,,I got lucky the hole in the platform is just big enough to slide the stub axle in. Then I ran the hub nut on to steady it while I tapped it.
side by side comparison of bolts
 Post subject: Re: Sprocket bolts
PostPosted: Wed Sep 09, 2009 9:13 pm
That oughta hold 'em , Marty!
............maybe. Might need some pins too when you mount them fresh cut big boggers. :wink:
PostPosted: Wed Sep 09, 2009 9:18 pm
Charles Lemonade runs this same setup with no pins with 42" tires and much bigger sprocket,,,this should be fine even with them KOKO cut boggers,,and oh yea I got one mounted and it looks KILLER :wink:
PostPosted: Thu Sep 10, 2009 2:06 pm
Glad to hear ya got your problem solved, Marty! Now get em mounted on 'er, I wana see them bad boys in action!
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Thu Sep 10, 2009 3:28 pm
-Dakotah/koko
sneak peak
