PostPosted: Wed Aug 12, 2009 10:15 am
I was installing my new 6 rib tranny and I found out that two CV bolts are broken off in the CV flange. Is it easier to just replace the flange or is there an easy way to get the broken CV bolt out.
To replace the flange, any recommendations on what flanges to buy and where...
PostPosted: Wed Aug 12, 2009 10:33 am
its real easy most of the time to get them out,theres no pressure on them,jus drill them out and get an ease out and unscrew them
PostPosted: Wed Aug 12, 2009 10:46 am
You may find when drilling them out they will spin out the back side of the flange. I would suggest you remove it from the trans to allow that to happen. A "C" clip behind the seal that holds it in.
PostPosted: Wed Aug 12, 2009 3:27 pm
I use left handed drill bits for broken bolts and studs.
PostPosted: Wed Aug 12, 2009 3:33 pm
Thats even a better method however most guys do not have them in there tool collection.
PostPosted: Fri Aug 14, 2009 11:45 pm
Left handed bits are to cheap not to have them as good a job as they do. I normally get them from enco.
http://www.use-enco.com/CGI/INLMK32?PARTPG=INSRAR2
John
PostPosted: Sat Aug 15, 2009 12:37 am
It turns out that the guy I bought my tranny from feels bad that the bolts were broken so he is going to replace the flange for free.
Thanks for all of the replys
PostPosted: Sat Aug 15, 2009 1:20 pm
What! I thought everyone was a tool junkie like me :shock:
PostPosted: Sun Aug 16, 2009 9:51 am
If its tool junkies you want to find you should go to http://www.garagejournal.com/.
Don't throw the old flange out. You can probably get the bolts out with it off the trans. If you have a MIG welder you can tack to the end of them and keep building it up until you can grab it with vise grips.
John
