It is currently Mon May 04, 2026 4:44 am
 Post subject: Sedan to 3 rib?
PostPosted: Mon Aug 10, 2009 7:02 pm
Going from sedan to 3 rib on Nitro Jr build. What all will I need?
 Post subject: Re: Sedan to 3 rib?
PostPosted: Mon Aug 10, 2009 9:00 pm
If you stay with stock width rear trailing arms you will need conversion axles,,,they are 15 5/8" . I have a pair leftover from another project if you are interested. Oherwise you will need bus to bug mount kit
http://cgi.ebay.com/ebaymotors/EMPI-319 ... ccessories
and also raise your shifter box,,or angle the shifter rod,,,I prefer to keep the shifter rod a strait as possible.
here is a kit with axles,,but they are too long :? ,,and the axles are too expensive too,,,
http://cgi.ebay.com/ebaymotors/IRS-BUS- ... ccessories
PostPosted: Tue Aug 11, 2009 5:06 pm
Marty I have some spare trailing arms. I assume they are Sedan, how can I tell? Or is there a difference.
PostPosted: Tue Aug 11, 2009 5:33 pm
here is a link to a pic on ebay,,,I think they are all the same,,bug,,thing,,squareback,,these can be beefed up .
http://cgi.ebay.com/ebaymotors/VW-Beetl ... ccessories
PostPosted: Tue Aug 11, 2009 6:14 pm
If you have the torsion, from the donor bus where trans came from, put it in the buggy.
That solves all you problems mounts axles everything, and the rotors from front will slide right on for disk brakes .
PostPosted: Tue Aug 11, 2009 7:23 pm
Currently has a sedan tranny and all matching IRS parts. Swapping in a 3 rib, would like to put bus CV's. Just trying to get as many parts for this build lined up so I can just go to town.
PostPosted: Tue Aug 11, 2009 8:56 pm
Find you 2 T2 CV's and firebugs axles with a bug to bus kit. I welded another shifter box on top of my old one to raise it. Its was easier than I thought it was. Check out viewtopic.php?f=12&t=6971
Tony
Tony
