| What weight oil do you run? http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=6351 |
| Author: | wreckincars [ Thu Apr 16, 2009 1:20 am ] |
| Post subject: | What weight oil do you run? |
So what weight oil does everyone run in there trans. I've just ran the cheap 80/90 in my car trans in the past but since I have a bus trans now I figured maybe I should look into this. So what do you run and why? |
| Author: | Kyle [ Thu Apr 16, 2009 8:48 am ] |
| Post subject: | Re: What weight oil do you run? |
We around here run 4 bottles of Lucas 85-140. |
| Author: | kendel [ Thu Apr 16, 2009 3:15 pm ] |
redline mt 90 is what my trans guy said to run in my vanagon box http://www.redlineoil.com/products_gear ... tegoryID=7 |
| Author: | chris38375 [ Thu Apr 16, 2009 7:26 pm ] |
i also use a gallon of lucas |
| Author: | Roy [ Thu Apr 16, 2009 8:17 pm ] |
I use Royal Purple 85W140. |
| Author: | afterburnt [ Wed Apr 22, 2009 11:26 pm ] |
steve, if you remember when i blew up my tranny and i had that thick ass 140 gear oil in there, remember looking at the spider gear pin? and how gulled up it was from the thick oil not getting between the spider gears and the pin. when brian rebuilt my tranny, he told me to use 90 weight. now i run royal purple 90 weight. |
| Author: | wreckincars [ Thu Apr 23, 2009 12:59 am ] |
I do remember that. I must have forgot to ask you that question. 90 weight royal purple it is. |
| Author: | Eric DeBord [ Fri Apr 24, 2009 7:47 pm ] |
Heavier oil will cushion gears better BUT will be harder to shift, especially when cold. You gain in one area, but you lose somewhere else. |
| Author: | Buckmaster [ Sun Mar 21, 2010 7:49 pm ] |
Ok guys im assuming that a quality 80/90 non synthetic gear oil will be alright to run in my tranny?I was also thinking about using 1 quart of Lucas gear oil and the rest regular because that Lucas stuff is some good stuff,yet expensive. |
| Author: | PhillipM [ Sun Mar 21, 2010 7:53 pm ] |
Millers CRX 75w90 NT, great stuff. |
| Author: | tw9294 [ Sun Mar 21, 2010 10:22 pm ] |
75-90 synthetic. |
| Author: | Maddog [ Sun Mar 21, 2010 11:41 pm ] |
Swepco 203 |
