It is currently Mon May 04, 2026 5:46 pm
PostPosted: Sat Feb 21, 2009 8:51 am
What slave and master cylinders are you guys uses on the buggys? Mine has a 3 rib trans if it matters on the application. thanks
PostPosted: Sat Feb 21, 2009 9:35 am
CNC
PostPosted: Sat Feb 21, 2009 3:12 pm
thanks, I have heard that cnc makes a good product. Never used any yet. What bore size should a man go with on the slave and master cylinder?
PostPosted: Sat Feb 21, 2009 10:12 pm
I think the slave only comes in one size, and the bore on your master cylinder depends on your brakes? (disk or drum)
PostPosted: Sun Feb 22, 2009 9:42 am
Slave cylinder only comes in one size. The master cylinder for the clutch, most people run a 3/4" bore I believe. (that's what I use)
You can use a 5/8 bore if using a stage 4 clutch. this will make it easier to push the petal.
