 Post subject: my first buggy
PostPosted: Fri Jan 23, 2009 6:52 pm
I just got my first rail and thought it had a bus tranny but come to find out it is a car . Would it best to go ahead and run it or go ahead and put the bus tranny in it? Im doing some more to it, and i can get the bus transmisson i just dont know how hard they are to change from swing axle to irs and what all it takes?
Last edited by windrock child on Fri Jan 23, 2009 8:04 pm, edited 2 times in total.
 Post subject: Re: my first buggy
PostPosted: Fri Jan 23, 2009 6:58 pm
Are you saying you have a swing axel (no CVs) now? If so Its not to hard to convert to IRS providing you have the jigs to weld the Pivot bracket on. As far as the car trans I would at lewast go with a 3 Rib Buss trans. The car trans is a lot weaker that the buss trans and the gearing is not real good for the woods.
PostPosted: Sun Jan 25, 2009 8:29 pm
Run what you have till it breaks, then do the switch. This will give you some time to save up all the parts to do the switch. :wink:
PostPosted: Mon Jan 26, 2009 12:41 pm
like mine i ran it till i riped the whole tranny out only if it dont have the baterry box in the rear corner
PostPosted: Mon Jan 26, 2009 6:02 pm
sorry for all the questions , but i reckon that is the only way i will ever learn. Excatly what all do i have to have to swith from my swing axle to irs bus tranny? Also are all bus transmissons irs rearends i was told they were.
PostPosted: Mon Jan 26, 2009 6:47 pm
not all bus rear-ends are irs,the first one was swingaxle to,with gear redux oxs on the end of the axles,makes one hell of a baja bug
PostPosted: Tue Jan 27, 2009 8:20 am
its not to much to it cut out your swing axle and weld in the irs and and u got to go and buy the bus trans mount kit which is like 30 or so bucks and when it comes to the shifting rod u will have to cut and angle it or double stack your box the shifter bolts to the buss sits up a lil higher than a car trans if im wrong in any way correct me lol and u will need to get 2 bus cv's 4 if u want to change your stubs out and go buss on bus which is much better
PostPosted: Wed Feb 18, 2009 7:58 pm
what he was saying about your shift linkage is correct, i ran into the same issue when i swiched to a 3 rib,rather than do alot of modifying to the shifter box they sell an adapter that bolts onto the rod from the tranny and then to your shift rod,about 20 bucks, i got mine from drews off road, it makes up for the 3 inch height difference or so that there is, saved me alot of time and head ache, works pretty good too, i did have to move my shift box back about 2 inches but i guess that will depend on how long your rod is! ha try it it is worth the money, good luck
PostPosted: Wed Feb 18, 2009 8:16 pm
I would recommend raising the shift box up rather than an adapter -- when i used the adapter it would work loose and the tranny didnt want to go all the way in gear.
PostPosted: Thu Feb 19, 2009 3:25 am
same thing here so i angled my sift rod and works great or u can stack the boxes i also have had that and did great
