Another 5 rib question
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=5235
Author:  Terry fryer [ Thu Dec 04, 2008 1:38 am ]
Post subject:  Another 5 rib question
I was taking the 5 rib out of my donor buggy. And on the passenger side hub they was a whole in the center. What would cause this and what is the fix? It looks like the axle has been hitting it. Thanks for any advice
Here is a pic
Author:  mudd mutt [ Thu Dec 04, 2008 3:30 am ]
Post subject:  Re: Another 5 rib question
Looks like the axle was to long,,is it wore on the edges?
Author:  Firebug [ Thu Dec 04, 2008 11:47 am ]
I've seen this before on my buggy too. Seems that the frame bending, braking,shifting, etc may cause a correct length axle to rub the plug.
Author:  turboblue [ Thu Dec 04, 2008 11:59 am ]
What length trailing arms?
Stock torsion?
Bus or Bug?
What CV joints?
Stock or aftermarket axles?
What length axles?
Author:  Terry fryer [ Thu Dec 04, 2008 12:49 pm ]
19 1/4 empi axles
bus cv's
5 rib
dean's trailing arm's I think 2x3
stock torsion
Author:  turboblue [ Thu Dec 04, 2008 12:59 pm ]
I use 18-3/4" for 2x3 and 19-1/4" for 3x3s.
That might be the issue.
Author:  Terry fryer [ Thu Dec 04, 2008 1:00 pm ]
Does that just get a plastic cap over it?
Author:  turboblue [ Thu Dec 04, 2008 2:45 pm ]
It's more of a plug than cap.
#14 in this diagram.
3 and 5 rib take the same plug.
6 rib and Vanagons are different.
Author:  chris38375 [ Thu Dec 04, 2008 5:31 pm ]
clean it up good and blue silicon,works perfect
Author:  wildwillie [ Thu Dec 04, 2008 6:12 pm ]
thats what i do.but i use black goo i hate blue!
Author:  Baddvw [ Thu Dec 04, 2008 7:07 pm ]
Terry, I put on red RTV silicone on it, those blue caps are liable to come off anytime and let gear oil leak out even though you can't see it unless you take the CV off of it to look at it. It is recommended by Eric DeBord. Also it looks like your are running too long set of axles, just like turboblue said 2x3=18-3/4 3x3=19-1/4.
Author:  Stevo [ Thu Dec 04, 2008 7:51 pm ]
If you take the axles out to replace with 18 3/4, I'll buy the old ones
Author:  Terry fryer [ Thu Dec 04, 2008 10:07 pm ]
What size arms does dean sale? When I bought the buggy the guy told me he got them from Dean.
