 Post subject: Cross shaft
PostPosted: Sun Nov 30, 2008 6:15 pm
I am upgrading to a Stage 4 pressure plate,,,got a deal on one on ebay...from a stage 2. I use a 3 rib bell housing. Will the stock cross shaft be sufficient? Can I expect it to be sufficient if I add more weld to the forks? What are other folks using...Oh yea,,I still use cable clutch too..thanks
 Post subject: Re: Cross shaft
PostPosted: Mon Dec 01, 2008 8:29 am
It oughta work fine if you weld it up like you said, 'bug. Thats what most 'round here runs.
Larry
PostPosted: Mon Dec 01, 2008 9:47 am
Firebug wrote:
I am upgrading to a Stage 4 pressure plate...Oh yea,,I still use cable clutch too..thanks
Let us know how that works out for ya. :mrgreen:
Aut Viam Invenium Aut Faciam!
PostPosted: Mon Dec 01, 2008 3:46 pm
I'd replace the cross shaft if it were mine.
Especially running a S4 plate.
The 3-rib housing has a bit weaker shaft setup over a 6 rib.
Just have to figure out if you have an early or late 3 rib housing.
Bugpack makes a good shaft kit.
http://www.bugpack.com/content.php?id=331
PostPosted: Mon Dec 01, 2008 4:44 pm
Cool,,,how do I tell what year mine is?,,,it has the dog ears for mounting if that helps. :?
PostPosted: Mon Dec 01, 2008 5:50 pm
That should be the later version.
What TOB does it have?
PostPosted: Mon Dec 01, 2008 6:18 pm
I replaced it but I am Afraid to say,,I will have to wait till I take the engine off. I am sure there is a tube and the PP has no collar
PostPosted: Mon Dec 01, 2008 6:39 pm
That is the late version.
Like this:
Hard to see with this straight on picture but there is a guide sleeve around the imput shaft.
This shaft has the full circle arm the TOB attaches to.
I swiped this pic off the net so I don't know if it is stock or replacement.
091 and some IRS sedans had a real beefy cross shaft.
Must use with pressure plate without the ring in the center.
This is the early version.
Has the TOB with the ears and hairpin clips holding it in place
Must use with pressure plate that has the ring in the center.
PostPosted: Mon Dec 01, 2008 6:49 pm
Thanks TB,,now I know what to ask Santa for
PostPosted: Tue Dec 02, 2008 12:51 pm
Santa is female at your place I assume......... :lol:
Tell her to email me and I'll hook her up........... :mrgreen:
