shifter
http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=4121
Author:  countri boy 84 [ Fri Jun 27, 2008 9:59 am ]
Post subject:  shifter
I've got a EMPI short shifter need about a quarter inch to engage reverse can it be adjusted or do i need a new shifter rod
Author:  harleyhunter05 [ Fri Jun 27, 2008 2:29 pm ]
Post subject:  Re: shifter
you can make an adjuster -- cut a piece out of your shift rod (about 3 inches) and pitch it -- weld nuts to the end of the other peices, and use a piece of allthread to replace the peice you cut out. remember to put 2 more nuts on the allthread before you put it in to use as jamb nuts when you get the adjustment you need.
