 Post subject: Back lash
PostPosted: Wed May 28, 2008 11:02 pm
I'm trying to put my superdif in and need to know what to set the back lash for the ring gear,,Help please :?
 Post subject: Re: Back lash
PostPosted: Fri May 30, 2008 2:03 pm
Set it the same as it was before you took it apart. If you failed to measure it, set it around .005 and you will be ok. Don't forget to get your side bearing preload pretty tight when you install the new diff.
Roy
PostPosted: Fri May 30, 2008 6:06 pm
Is that where you tighten those big nuts :shock:
PostPosted: Sat May 31, 2008 7:14 am
Yes, those big screw collars.
