| Where do you get 19 1/4 axles? http://woodsbuggy.com/phpBB3/viewtopic.php?f=12&t=3353 |
| Author: | gkeeton [ Tue Mar 18, 2008 8:12 pm ] |
| Post subject: | Where do you get 19 1/4 axles? |
From what year of Bus/Vanagon, and type of trans, did VW use a 19 1/4 inch long axle? I'm trying to locate some for a buddy that recently got some 3x3 trailing arms. Thanks! |
| Author: | Roy [ Tue Mar 18, 2008 8:13 pm ] |
| Post subject: | |
No bus that I know of has that length. Aftermarket would be your only option. |
| Author: | purplerail [ Tue Mar 18, 2008 9:00 pm ] |
| Post subject: | |
stock bus axels should work |
| Author: | gkeeton [ Tue Mar 18, 2008 9:33 pm ] |
| Post subject: | |
The stock axles from the Buses with 3, 5, and 6 rib trannies are 18 3/4, which I though only worked with 2 X 3 arms. I've spoken with a few people that say the 19 1/4 axles come from a Vanagon, but when you ask them from what year, with which trans, they don't have any idea. I found some from a 91 Auto Trans Vanagon, and they were different lengths that were both over 20 inches long. |
| Author: | RaceBugg1098 [ Wed Mar 19, 2008 7:43 am ] |
| Post subject: | |
you can just get the empi set, they are reasonablely priced |
| Author: | RailHomie [ Wed Mar 19, 2008 9:53 am ] |
| Post subject: | |
Yeah, I've been trying to find some used ones for a little while now. Not really any to be found (as Roy said, they aren't stock). I think I'm gonna have to buy some new ones(about $135). |
| Author: | k.elliott [ Wed Apr 02, 2008 9:37 pm ] |
| Post subject: | |
i need them also i know appletree automotive carrys them. 130 for the set. the site is www.appletreeauto.com number is in hot vw's kevin |
| Author: | hillaholic [ Thu Apr 03, 2008 9:22 am ] |
| Post subject: | |
Ebay has some. http://cgi.ebay.com/ebaymotors/sand-rai ... 0208661613 |
| Author: | sharpshooter [ Thu Apr 03, 2008 7:03 pm ] |
| Post subject: | |
You can run stock bus axles 18 3/4 out of a 70-79 bus just add a1/2 inch spacer on your stub axle |
| Author: | turboblue [ Thu Apr 03, 2008 7:06 pm ] |
| Post subject: | |
VW made 19-1/4" axles just not sure what they came out of. I've had several sets in here. Maybe Vanagons?? |
| Author: | m.ralston [ Thu Apr 03, 2008 8:01 pm ] |
| Post subject: | |
[quote='sharpshooter']You can run stock bus axles 18 3/4 out of a 70-79 bus just add a1/2 inch spacer on your stub axle[/quote]Never heard that one before! |
| Author: | sharpshooter [ Thu Apr 03, 2008 8:16 pm ] |
| Post subject: | |
It works,it puts your stub axle in toward your tranny flange making up for the 1/2 inch difference in the axle 18 3/4-19 1/4 axle |
| Author: | bhallOU [ Thu Apr 03, 2008 11:25 pm ] |
| Post subject: | |
i put bus axles in my 3x3 trailing arms... i think i used the 1/4 inch spacers on the stub axles ( no sure tho ).. you probably wont be able to put the cotter pin back in the nut but i didnt have any problem with them loosening up.. just check em the first couple rides.. its a better way to go unless up want to spend mo money. i never had any problems.. |
| Author: | m.ralston [ Fri Apr 04, 2008 8:39 am ] |
| Post subject: | |
[quote='bhallOU']i put bus axles in my 3x3 trailing arms... i think i used the 1/4 inch spacers on the stub axles ( no sure tho ).. you probably wont be able to put the cotter pin back in the nut but i didnt have any problem with them loosening up.. just check em the first couple rides.. its a better way to go unless up want to spend mo money. i never had any problems..[/quote]How does the inside seal work? |
| Author: | bhallOU [ Fri Apr 04, 2008 5:38 pm ] |
| Post subject: | |
i'm sure its not as good of a seal against the spacer as the stub axle, but it works. i never had any grease problems.. that was one of my first alabama rig jobs on a buggy. |
