It is currently Mon May 04, 2026 2:19 am
PostPosted: Tue Mar 18, 2008 4:47 pm
Anybody have a link or know where else to find a chart or something listing the STOCK R&P's and 1st-4th gear ratios of 002's, 5 ribs, and 091's?? I've looked all over the internet.
Also, where to find same info for full auto tranny from '84 vanagon, watercooled?? Found some info, but it referred only to diesel bus trannies.
Thanks,
PostPosted: Tue Mar 18, 2008 5:24 pm
Check with Eric. He should be able to help.
PostPosted: Tue Mar 18, 2008 5:48 pm
Gears
PostPosted: Wed Mar 19, 2008 1:17 am
Thanks guys!
According to the chart, an auto in first (4.571r&p x 2.06gear=9.41), is slightly higher geared than a stock 6 rib in second (4.857r&p x 2.60gear=10.005), right?
PostPosted: Wed Mar 19, 2008 6:17 am
your 6 rib r/p looks like a 5 rib?
PostPosted: Wed Mar 19, 2008 7:28 am
Call Chuck he can tell you what you need to know Larry.
PostPosted: Wed Mar 19, 2008 8:39 am
[quote='Firebug']your 6 rib r/p looks like a 5 rib?[/quote]
You are right Fireplug!! Duh! It was like 1 am when I was lookin at this stuff, my eyes were pretty heavy!!
That chart is kinda screwy, too. Looks like some of the boxes are not in the correct columns.
I assumed the last row (80 Vanagon) was ratios for automatic, since it had only three gears listed. Same as '74-'75M row.
I also dont understand why the '76-'78A row has a 5.429 listed and '76-'78 row right above
PostPosted: Wed Mar 19, 2008 9:34 am
A little info here
http://www.ratwell.com/technical/Transaxle.html
http://volksweb.relitech.com/helmut/GEARBOX.HTM
