 Post subject: Chain Drive maintainance
PostPosted: Sat Mar 08, 2008 4:36 pm
OK Chaingang,,, how bout some pointers. What do yall use to lubricate the chain ,,also how tight is tight enough , or too tight,,or too loose.
PostPosted: Sun Mar 09, 2008 12:03 am
i oil mine with motor oil and tight but not too tight like a motor cycle chain
and oil them when you hear them they will let you know
PostPosted: Sun Mar 09, 2008 8:01 am
Tractor supply sells a chain and cable lube that we used on the winch chains and cables on the tow trucks where I used to work. It worked for that, it should work for yours. I would use chain lube from the dirtbike shop if I had chains.
PostPosted: Sun Mar 09, 2008 9:16 am
I use to use a product called Kell Lube on my RM250. It is used for the fifth wheel on a truck. It sticks like glue and holds up well.
PostPosted: Sun Mar 09, 2008 9:47 am
another thing that sticks like glue is lucas oil treatment
PostPosted: Sun Mar 09, 2008 2:14 pm
I use a lube with teflon so it stays on the chain. Busby uses oil or what evers around. JUST MY TWO CENTS.
PostPosted: Mon Mar 10, 2008 10:17 am
if it is sticky dirt will stick :!: sprockets an chains will last about a year.use
motor oil mine are 4years old
PostPosted: Mon Mar 10, 2008 5:06 pm
The best thing to use if KY JELLY it keeps the friction down. :eek: :eek: :eek: :eek: :lol: :lol: :lol: :lol: See you all in AL.
Kathy
"It is better to trust in the LORD than to put confidence in man".
http://www.dandkoff-roadpark.com/forum.html
PostPosted: Mon Mar 10, 2008 7:11 pm
You aint right there railrider, was funny.
The Wild Kids
PostPosted: Mon Mar 10, 2008 11:43 pm
What do they use on a motorcycle chain? Bigun I said it was my two cents. Didn't say it was worth a shit.
PostPosted: Tue Mar 11, 2008 3:54 pm
are you coming to the hill climb :?: is your motor ready yet :?: is buss coming with you :?:
PostPosted: Tue Mar 11, 2008 11:08 pm
They tell me it will be ready. I'll be coming into town Friday and install the motor Friday/Friday night. I hope everthing works right, so I can ride Saturday. If you feel like helping, let me know.
PostPosted: Wed Mar 12, 2008 4:49 pm
[quote='railridernky']The best thing to use if KY JELLY it keeps the friction down. :eek: :eek: :eek: :eek: :lol: :lol: :lol: :lol: See you all in AL.[/quote]
Hey Wes,,how 'bout bringin some of that Ky jelly with you when you come to Bama. I'm ready for them hill climbin lessons you promised too. :wink:
PostPosted: Mon Mar 17, 2008 8:13 pm
If you want to win you better not listen to me. :eek: :eek: :lol: :lol: :lol:
Kathy
